Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I don´t know if this is right place for suggestion for improvement. Is it possible to make two failsafe for battery? I like to have one safer limit and use RTL and if battery get critical I like to use Land.
    • Place your request here.  This is where folks place requests for fixes, or enhancements.
      You can also ping DEVS at Drone-Discuss but only for serious discussions.  This location is where the collaboration takes place between developers.
      • Thanks:) I am new with drone but now I have setup enviorment so I can compile firmware by my own and maybe start to help adding functions.
  • Hi all,
    All my apologize for my first comment but, last Sunday i did a auto tune, that seems to pass well.
    by the end of the auto tune, the quad seems to fly well, i finish my battery by a RTL, every thing seems ok, when i return to my housework, had a look on PID, and find similar result as a lot people here.(ex: old rate pitch P:0.31, new:0.088... strange but why not)
    Yestreday evening nice weather, let's have a flight! 2 min in the air, quad is unflyable!?
    I saw that the autotune is not ready, but what misunderstand is why i manage to complete autotune, test it on sunday and yesterday nothing go right?
    it's like if it don't turn on the new PID values by the end of autotune (according to the auto tune process), and write the news  PID value only when i disarmed it, (and stay on the old ones during the test of news ones)
    if it could help:
    Autotune flight log:
    https://www.dropbox.com/s/51xn25628p2pyw1/2015-04-12%2018-14-22.bin...
    Bad PID flight:
    https://www.dropbox.com/s/z9dvo6q5c1tg4u8/2015-04-14%2019-12-26.bin...
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Hi Vic33,
      After autotune you should land and disarm then take off and fly again to test the pids. You can also test them by moving the autotune switch back to the off position and back to the on position. Be careful though as a bad tune may need you to quickly switch back to the the off position.
      • Thanks leonard,
        But i know that, as i don't make a autotune every days, just before i had a look on the process to refresh my memory, and i'd choose the second method, that why i surprise, at the end of the process i'd turn off auto T , then switch on.
        it's could be me that dreamed, or due to my 3 position switch (taranis) for autotune that i'm not full turn off by just put it meddle position? even if auto tune on/off is confirm by MP in my workshop...
        Don't be affraid, i'm used to pilot, i've 9 years of flight experience on this type model (multirot), and i have the chance to have a great area test zone with about 2m height of reeds for the "dangerous" test, moreover as it's dev quad, if it crash i'll don't cry ;-)
          Hi Vic33,
          No problem, thanks for your feedback and help!!
          • you're welcome.
            my only regrets is that I've no skills in coding :-(
            and a poor English ;-)
    I've updated the Warning #1 to tell people to hold off on trying AutoTune until -rc2 comes out which will include some fixes from Leonard.
    • Hi Randy,
      Wasn't auto tune supposed to be repositioning during the tune phases, incase you experience drift off due to wind influences.
      I thought I did see this in the asome video of Marco where he did test the auto Tune?
      Just flew into a tree during auto tune, as the last phase (the yaw tuning) is changing the orientation, and getting it back when the Front of the hex isn't where you expected it to be, makes it a little harder to stear away... (Pure operator error, as the autotune did go fine)
      Unfortunately by hitting the tree it dropped into a pool of water, so using an airblower now to dry it out, taking every component apart..., I could get it out of the water in just seconds, so hopefully no expensive parts lost (did lose a motor / esc, which was smoking when I got it out)
      Log is available incase Leonard needs it.
