Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • Great work, thanks!  Is it possible to retract/lower through auto mission commands?  That would be awesome.
              • Not yet, but hopefully eventually.
    • got it to work.
      for the RC output you need to select 29 as the option. Was not listed in the options in the latest update of mission planner so I guessed since 29 was listed for the CH option.
      I'm using CH 8 as my gear switch and aux1 as my servo output. In mission planner:
      Select CH8_OPT to 29 - landing gear
      Select RC9_FUNCTION to 29 - (unlisted function)
      Use LGR settings for servo throw and direction.
  • You could see the log
  • GPS on UAVCAN initial report
       I broke the cardinal rule and made two modifications at near the same time so have to dig a bit deeper to determine results.  I updated to 3.3 with no changes to PID tuning or any changes other than resident changes to 3.3, with that my carbon 550 quad flew better than I have ever been able to do in full sensor control modes.  I have had twitching problems in loiter since 3.2 and a couple of hard landings.  Now it is as stable and predicable as my Iris (my benchmark).  I have now flown several flights after installing a Zubax GNSS on the newly found UAVCAN Bus and have been impressed with initial results.  Two flights in GPS control modes under partial cloudy sky and sub .4 HDOP with >16 Sats resulted in repeated RTL's within inches of launch point and totally predictable rock stable loiter attitude.  We all know that HDOP and number of satellites is not the whole picture but flight performance indicates that the folks at Zubax have done a better than average job of noise isolation with the GNSS.  I have been using two other well know M8N units with slightly less results across the board.  At this point I think 3.3 made a big improvement in overall performance and the Zubax increased GPS accuracy without noise complications.  I'll be doing more in-depth testing on multiple platforms and will report any significant results.
    A big thank you to the Developer team and Pavel at Zubax
    RB
  • Upgraded to 3.3rc1 and it appears that the gimbal is not being controlled properly.  The Tarot gimbal on my 3DR Y6 works fine with 3.2.1 (RC tuning knob, ROI, etc), but the only time I can get it to move in 3.3rc1 is to hit the servo low/high buttons in MP.  Reverting back to 3.2.1 restores functionality.
    It appears that others have seen this as well earlier in the thread, though with a different gimbal.
    Any ideas?
    • Still got the alexmos issue here with 3.3rc1... The Alexmos board connected to the Aux port in pixhawk was perfectly working in 3.2.x, as if it was just controlling a servo with pwm, but on 3.3rc1, the sAme setup fails to work, reverting to 3.2.1 restores functionality of gimbal...
      Other than that, the 3.3rc1 is way better than the previous firmware.
        Erwin,
        Ok, this is almost guaranteed to be because of the changes to MOUNT.  If you set MOUNT_TYPE to 1 it should work again.  You're about the 4th person to hit this issue so I guess we need to do something to automatically set that parameter.  For now I'll put a note at the top of this discussion.
        • Randy,
          Actually, it looks like any servo based gimbal control is broken.
          I had a long try last night, setting mnt_type to 1, which should activate the servo based control again, but by using the RC11 for pitch, and RC10 channel for roll, I can't get any movement in the servo's which did work fine with V3.20.
          Also had a look at the MNT__DEFLT_MODE = 3, but to no avail... (Tried other values as well)
          I do power the aux ports externally to drive the servo's like I did in v3.20 as well.
          Even tried to hit the safety switch, to see if that was enabling the pitch and roll stabilization, moving the frame around...
          Erik
          • Hi Randy,
            Ignore this one please..., by putting the RC control channels in MNT_RC_IN values, it started working like V3.21 again, when MNT_TYPE = 1
            Erik
