Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Hi DG,
          my complete hardware setup guide is here:
          Hardware Setup for AUAV-X2
          At the end of it, I added a small (330-470uF) capacitor to the 3rd party power module, which seems to fix startup problems due to a noisy 5.3V supply, as one user reported.
          PS: Although the 3DR V2 telemetry supplies RTS/CTS, I don´t use it. I prefer SERIAL 2, but just because its easier to access .
          As soon as Arducopter allows free config of the serial ports, I´ll use SERIAL 1 for the 2nd GPS.
          @Reuben: If you fear high current draw by the telemetry module @ the serial ports (due to the current limit of the internal buck boost reg)., you can power it directly by the power module, just disconnect the +5V .
          • I cannot get serial 2 to work on this RTFQ radio; haven't tried Serial 1 but 3DR V2 works fine on Serial 1.
            For  $30 it was a low cost alternative to the 3DR version, but I'm done messing with it, will bite the bullet and get the 3DR.
            • this is not Radio's fault.... I have tried multiple radios and even an FTDI connection through 2 of the serial ports in-front of the X2 they seem to be non-functional at least on my board. I have spliced the serial connection from the serial port near the USB as a work around, but soon I will be connecting an alexmos gimbal  and will need to figure out why that serial connection doesn't work. (this is my only complaint about X2). I will try running 3.1.5 and see if that'll help as well as I'll try to power the accessories I am connecting to the serial ports separately (minimOSD, teensy and the telemetry radio)
        • Hi guys .. I have just spent the last 4 hours testing the different radios with two AUAV X2 boards.. it does seem there is a difference, when using 3.1.5 it appears to connect the most reliably, i.e first go On UART2 (S1).. 3.2.1.and 3.3 I have to attempt to connect a quite few times before it takes almost to the point of giving up .. I have noticed that using the other port UART3 seems to be better at connecting on the first go. but I am lead to believe UART3 has a lower amp rating than UART2  I also notice in the parameters screen there are different Parms shown in the S0 S1 S2 Ports section between 3.1.5.and .3.2.1. ..If I enable CTS and RTS .. I can not connect at all in any firmware version ? One radio has the CTS and RTS wires connected to the UART 2 port ..so 6 wires I assume you connect CTS and RTS crossed as you do with RX and TX ..anyway I tried both ways and no go ..
          • I am using only the Rx and Tx, not CTS/RTS so try to connect via S2 (4 wires).  The radios talk, but Mavlink connect is a no-go.
            • Hi .. have you tried to switch rx and tx wires around ? also try the UART3 connector pins I find these were connecting well ..if you have trouble with the UART2 plug ..Which firmware do you have on the radios and also which FC firmware are you using?
              What I have noticed is .. IF the little RED LED is blinking on the AIR side radio.. Then you will Know for sure it will connect when pushing CONNECT in MP .. if the red led is not blinking slowly ..then the FC has NOT seen the Radio .. re boot ..or check RX and TX wires
              • Rx > Tx and Tx > Rx.....that's how they are wired for the S2 pins. I have not yet tried UART2. What type of connector is it?
                FW:
                1.9 on the radios
                3.3 rc1 on the FC
                On the air radio, there are 6 solder pads. Do you know what corresponds to RTS and CTS?
                EN
                TX
                RX
                VCC
                CO
                GND
                • HI DG .. sorry no I don't know which two are CTS and RTS .. for now don't worry about connecting them .. it usually does not need these connected  just use VCC GND and RX TX  did you try switching them ? I take it you are using UART 3 .. Also be very sure the settings are the same on each radio .. and make sure CTS enable is UNTICKED
                  Quick googling will return CO -> CTS, EN-> RTS
  • Hi
    Tests Quadrocopter all the time and I have a problem that previously did not exist. Increased vibration levels appeared cyclical peaks, perfectly balanced drive, hovering vibrations contain from +1 to -1, and never had these peaks are now shown on all axes. Despite such a bad plot, quad very nicely and predictably behaves in the air. I do not know whether to worry about the vibrations? is it normal that the x and y axis spread, during a quick flight up to the speed of 22m / s
    3701988045?profile=original
    2015-04-23 19-29-06.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3701988143?profile=original
    • T3
      Wow! This looks weird!
      This is very periodic. The question is where the vibes are shown more accurately: in the case of the peaks on in between? If it are the peaks the vibes would be much too high. Strange. Need to test rc1 asap.
