Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi paul,
I have to disagree with not tighting cables,that way they are vibrate from air flow as well and make thing worse...correct way is to cut that foam latex,wrap it around cables and fix them somehow,so they don't touch mounting plate...
Pascal,
Make sure you reboot the Pixhawk after the firmware update. There shouldn't be any changes that affect the GPS data but there are some additional pre-arm checks that can make a "Waiting for 3D Lock" or "Waiting for Nav Checks" messages appear. If it's something else that you're seeing a dataflash log would be good.
VP,
You are very observant! What you're seeing is expected but we didn't include it in the release notes because it's a detail that most won't care about or even notice. In short the barometer altitude is tied to the "EKF Origin" which has been separated from the home position.
This was required to support the do-set-home and return-to-me features because the EKF position estimate and our navigation code was not happy if we keep changing their reference reference point as we updated the home position. For the most part everything the user sees is relative to their latest home position but internally most things are relative to the EKF origin. The baro alt, dataflash CTUN and NTUN messages are all relative to the EKF origin.
Here I attach the last log of flight with 3.3 rc3. I also believe that with the new version 3.3, pixhawk is more a bit a capable to the vibrations in certain circumstances. Also I attach photo of my system antivibration. If they need some kind of more do not hesitate to ask for it me. Regards
aggressive flight
aggressive flight 1.
autotune.rar
How do we calibrate the channels 9-12? I already set the parameters for those channels. but in radio calibration tab, only channels 1-8 can be calibrated for end points.
Erwin,
There's currently no way to calibrate those channels and from what I know it's not necessary because the RCX_MIN and MAX parameters for those channels aren't used. For example if using them for auxiliary switches, the pwm ranges are hard-coded so <1200 is low, >1800 is high. If using them as a passthrough to the servo outputs then there's also no scaling required (what comes in from the receiver is just directly piped out to the corresponding output channel).
since RC3.2 release the pixhawk has become more sensitive to vibrations (for better filtering). it is very important to have tuned foam pads which are only available form 3DR. what is important is the damping effective of foam when pressed and released. they may look to be same but 3DR has tested the foam on vibration machine (I think so). I had a problem of vibrations when I upgraded form 3.1.5 to 3.2. by changing to 3DR foam the issue got resolved. also the FC should not be touching any part of the frame. and most simple and important step is to balance the props.
Ravi,
Thanks for the input. I also recommend the 3M foam that 3DR sells. Paul Riseborough thinks the HobbyKing ping foam (sorry I don't have a link) may be even better but it's not sticky on both sides so it's a bit more trouble to use.
We really don't think that copter should be more sensitive to vibration between AC3.1.5, AC3.2 and AC3.3. We're attempting to make it less sensitive to vibration by increasing the accelerometer range from 8g to 16g, improving the fitering, increasing the read rate from the accelerometers, etc so I really hope that's it's not getting more sensitive.
If you really think it's more sensitive we'd like to see a log. I know it's hard to prove it's more sensitive, it probably requires using a borderline vehicle and running back-to-back tests that show bad behaviour on the new firmware but not on the older. I know it's a big ask but I've never seen such a test done.
Sorry for my ignorance, but I just bought Zeal pads for my Pixhawk, and it seems, reading posts here, that Zeal isn't anymore the recommended solution.
Why is that?
I had almost no vibration with them on my other APM2 quad.
409
410
411
412
413
of 449 Next
