Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Everything looks fine and then it falls out of the sky. Only issue I can see is RCOUT->CH4 looks clipped to me at the end (i.e. hit the maximum output), so maybe you had a gust and the motors couldn't compensate.
re- 5) EKF fixes/improvements
a) prevent yaw errors during fast spins
Would this be related to the 'DCM Bad Heading" warning? It seems to occur more with fast spins in 3.2 anyway.
Richard,
Yes, in AC3.2 spinning quickly leads to a heading error which triggers the DCM check. AC3.3 uses the EKF by default (DCM as backup only) but it was suffering from the same problem. In case it's of interest, the underlying issue (according to Paul Riseborough) is that we don't correct for the gyro *scaling*. So the gyro readings are accurate when the vehicle is rotating slowly but once it's spinning quickly the gyro readings can be off by up to 5deg/sec. There's some talk of trying to learn that gyro scaling but it's a little tricky. The fix was to stop trying to learn the gyro drift (which is where the scaling errors would show up) while spinning fast and instead use the compass more.
Thanks Randy
New to the PX4Flow discussion - two questions I have,
- is the reading from optical flow is used by Pixhawk if GPS is enabled? (or can it be used as backup in case of GPS glitch)
- does PX4Flow require onboard sonar or without sonar but with Lidar mounted (pwm) would it work correctly (Wiki page video indicates a "yes" answer)
Thanks,
Tom,
Ok, we've found and fixed this bug in which the vehicle slowly descends in Brake mode. This will go out with -rc6. Thanks for the report!
Hmm... I see that. Odd. It seems to happily allow the copter to slowly fall. Will have to look into this. I'm not sure if it is the same for all, or if it only affects when using Rangefinder.
Hi, been flying Tarot 650, 15inch props, 470kv motors, Pixhawk with AC v. 3.2.1 without a problem, PID gains from v. 3.2.1 autotune. With version 3.3 RC4 it is rather unstable, motors pulsing in Alt Hold and Loiter and the quad is not able to maintain altitude properly as before. Log is attached.
2015-05-18 22-08-29.log
Hi Arni,
I have been talking to Paul about this and you have set EKF_GPS_TYPE to 1. That means you arn't using the GPS velocity in your alt hold estimate. This isn't helping things.
Paul suggested if you have non standard parameters you should probably do a full parameter reset and start again from scratch.
There are some other parameters that have changed too now I think about it. The alt hold pid names are now different. Have you changed them from default, if so they are not back to default.
So set EKF_GPS_TYPE to 0 and check to make sure your alt hold parameters haven't changed.
Hi Leonard
The flight today ended in crash. EKF_GPS_TYPE set to 0 but cannot see much improvement in altitude control. Like the other day it was light wind with some gusts. One gust of wind maybe 5-6m/s and the controller did not manage to keep it stable and down it went. It flies well in stabilize though despite the wind. I guess the autotune parameters from version 3.2.1 are not good for 3.3RC4.
-Arni
2015-05-22 21-47-05.bin
390
391
392
393
394
of 449 Next
