Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Today I had a small crash with 3.3 RC3+: Before landing accidently I switched to drift mode. After landing I want to disam via yaw stick but the copter flipped on the ground. I think it should be possible to disarm the copter in every flight mode. I know thats stupid to land in drift mode, but when done disarming should be possible.
    Cheers Gregor
  • Looking forward to RC4  Best guess on when it will be available?
    • Randy is going to be trying for Sunday.
  • To all the developers,
    will the "follow me" mode be smarter on the succeeding builds? I would love to see it perform better in follow me mode, like filming you from behind, or from your side. I think as of now, it is limited to fly above you.
    just sharing my opinion. :) thanks again!
    • Nice! That's great news :) something to look forward to, :) thanks again.
      We are continuing to improve the performance of the follow me controllers. As Randy says, the rest is done from the ground station.
      • That is great. Which gps ( and link to the laptop running mission planner ) is recommended on the "me" side?
        Thank you
        Henri
        • Note to self: google USB GPS and there are the answers...
          wiki follow me
      Erwin,
      you know we don't actually have a 'follow-me' feature in copter.  It's all just done with guided mode's position or velocity controllers.  We could add a follow-me mode but another option is for the GCS developers to do it... and I think tower supports all kinds of things like orbit and "lead-me"... I think..  I haven't tried it myself..
