Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • following the wiki page :http://copter.ardupilot.com/wiki/landing-gear/ but can not got the landing gear working.
    set RC12_FUNCTION to 29 , plug landing gear to AUX4 , set ch7 opt to "landing gear", nothing happend when switch being fliped.
    • Can you attach a log please?  I'd like to look at the settings, PWM signals, etc.
      Lijingwei,
      One thing we haven't mentioned on that wiki page is that an external BEC is required to power the servos.  So the Pixhawk does not power the rear servo rail on it's own.
    • Maybe you have to adjust the pwm settings a bit? For me it is working fla
  • Just have a new feature request for next release as follows, in case a crash is detected the buzzer should start to beep. This could help people find the copter.
    • Yes I like that too.
      +1 here
      Pomaroli,
      There's a lost-copter alarm that will sound if it's attached to an aux switch (aka ch7/ch8 switch) and there's also a special transmitter stick move which is: right stick down and right, left stick down.
      • Cool feature, good to know.
      • The Lost copter alarm works really well. Tested is a couple of days ago and it's nice to be able to let it beeb once or continue to beep as long as the stick is held down / right
        1:10 in the video
  • Has anyone else tried to use serial 4/5 with storm32? I have got it working only in tele2 port. How ports and configurations match? Are ser1-4 configurations tele1,tele2,gps,ser45?
