Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Does it seem overall more able to keep the copter at a steady height off the ground even in turns etc? As JoeBob points out it seems any pitch or roll would effect it's reading and end up thinking it was higher than it was. Thanks for the report...
+1 why I want one.
PhillNZ,
So I guess the mount is not moving is the issue? Could you try setting the MOUNT_TYPE parameter to "1"? Definitely we will need to update the defaults and/or the MP mount setup screen before the AC3.3 release it seems!
Follow-on information to my earlier post.
I captured a picture of one of my test flights. In the image on the left side of Mission Planner HUD and Quick-look screen. On the right I had the Sonar Voltage (Blue) and Sonar Range (Green) displaying during a telemetry replay. I'm assuming at this point in my analysis that the Sonar Rng deviation is a byproduct of it performing samplings.
The video embedded is a snippet of a long video I took. It demonstrates the LiDAR activation process (lifting to 50cm) before you are able to arm the copter.
Attached is a Dropbox URL to allow folks to download the mission logs. Click here.
One suggestion for Michael Osborne, please allow Sonar Range to be configured for either Meters or Feet. I believe all measurements in any part of the Mission Planner should be configured to whatever any one person setup up in the "Distance" and Speed" fields in the CONFIG/TUNING - Planner section. I use Feet and MPH and the Sonar Range in the Quick Look section of the main page only shows in meters.
re
+1 ! It can certainly be confusing sometimes if one or all the data and entries are one or the other.
Ok, I've decided to give RC-4 a chance for autotune and upgraded from 3.2.1 (which ran good but ). The first thing that popped to me after uploading the firmware is errors: "EKF PRED POS HORIZ ABS" and EKF POS VERT AGL. I have tried looking them up in the wiki, but I suppose these are too new to be there yet. I've tried reloading parameter to default w/o positive result. Please advise what these errors are about and how to get rid of it?
Thanks!
I found this error appearing on the mission planner as well when I upgraded the MP beta. I think it's more of a mission planner issue than a copter issue. The EKF status message is a new one for AC3.3 so we just need to work with Michael to make sure it's being interpreted properly.
ahh yes, I figured that could be the cause as when I started going through the EKF tree i found that for some reason my EKF_ALT_SOURCE was set to use something other than baro. After going back to a stable MP and reloading the firmware all is good now!
Loaded 3.3 rc4 today and did a complete recalibration with an IRIS.
Actually flew quite well. The only problem I saw was after a short but uneventful flight. I flew in stab, poshold and Loiter and did a manual landing.
When I checked the datalog, the analyzer told me that I must have had a brownout, as the IRIS stopped transmitting at about 9m.
When I checked tha log, the altitude started at about 3m and ended at 9.
Later I connected on the bench with USB. It was sitting for a bit, and when I looked at the HUD it read 11.5m. on the desk. I'm used to it climbing slowly as it warms up, but usually when I ARM, the altitude resets to zero. This time it didn't. So any altitude drift remains. I haven't tried, but I imagine if I reset the altitude would go to zero and probabaly wouldn't move to much more..I haven't been paying as much attention to the details of development, but still check several time per week, but don't remember anything about this.
387
388
389
390
391
of 449 Next
