Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  •  A bump on my problem of 12 hrs ago.
    I see that the altitude drift after  initial  boot isn't reset on arming. Is there something new there?
    Yesterday, I took off from +3m and landed at 9m. This would affect autoland. (in this case I did a manual land.
    WHen I tested on the bench, the altitude read near 12 meters after only about 5 min. It didn't reset on ARM.
    This last test was indoors without GPS, however a similar result occurred previously outside with HDOP of 1.3
    Anybody know what's going on?
    I'm going to fly today. I'll try letting it "settle down", then reset power, its shouldn't deviate much from zero on the ground, but that's not a reasonable fix.
  • Hello @ll,
    sorry if I overread the solution to my problem but I still cant find it in any forum. I have a PX4FMU + IO and APM 3.2.1 runs fine on it. I can upload to 3.3rc4 with mission planner but then I cant connect anymore. I'm trying APM Planner2, Mission Planner and qgrountcontrol. None of them connects. Just a timeout. I also tried different speeds but it doesn't work. I can then go back to 3.2.1 and everything works fine again. Does anybody have an idea how to solve this?`I see people running 3.3rc4 on PX4 here in the forum...
    Thanks and greetings from Austria
    Gerald
    • Hi
         I have done autotune with v3.3 r/c4   twice now and notice that rate P and rate I are identical in roll and also in pitch,  (5 decimal places ) coincidence?, part of the algorithn ,or bug?
      any way my Y6 flies so sharp and crisp now I am very pleased Thanks all.
       Tim Painter
        Hi Tim,
        That is part of the algorithm.
        Glad you are happy with the results!!
        • Hi
              Yes i think auto tune is truly sorted now.   just one thing after autotune completes I land with autotune selected and as soon as the legs touch down  the tri (y6) copter does a bucking bronco act, finaly fliping before i can disarm . This has happened every time ( thank heaven for soft grass) normal flight landings are easy(stabilise)
             Any way Thanks again for working on v3.3
          Tim
  • This is a bump forward from Monday. My sonar worked fine with 3.2.1 but I get an error message with 3.3 rc4...
    I set up my sonar (1240 analogue) and I get accurate readings in Mission Planer but I can't arm the quad. I get a "prearm check rangefinder" message. I have to disable it by setting RNGFND_PIN from 14 to -1 to arm the quad. Is this a bug in 3.3 or am I doing something wrong?
    • Hey Terry
      Pls do this -> "The check can be disabled by setting ARMING_CHECK to Skip Param/Sonar." U found the Parameter in the Full Parameter List.
      Greetings, pit
      • Thanks Pit, I'll give that a try but I wonder why the prearm check fails?
