Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • HI leaonardt, thank you for looking into this. You might remember we already spoke couple of time regarding autotune on tricopters. Couple questions, do you need some of the regular logs as well, or only those with autotune?
        I will reattach the 3.3 rc4 autotune log here.
        edit: and last 3.2.1 atotune as well
        2015-05-20 18-47-20.7z
        2015-05-20 14-10-58.zip
        https://storage.ning.com/topology/rest/1.0/file/get/3702699616?profile=original
  • A couple more tests on the bench.
    As suspected, once the unit warms up, a power reset shows less altitude deviation, it only climbs to about a meter in a couple of minutes and stabilizes. But it doesn't reset on ARM.
    • I had this happen a few weeks ago on a new DIY Pixhawk quad build running 3.2.1.  Was causing false altitude reports and RTL did not climb to min altitude before starting the return flight.  Had a few RTLs at 6 feet altitude.  Fortunately was in testing mode so NHNF.  Ran the MP Terminal Baro test several times and it clearly showed the altitude drift.  Thought it was a bad barometer module so I contacted 3DR for a warranty replacement.  They asked that I send the log files which they analyzed and reported back that the log files showed that all was well.  Did not see in the logs what I and my friend who was there observed.  The tech (who was very nice and supportive) asked for a video of the reported behavior along with the log file.  Went to the field to make the video but when I triggered RTL, all worked properly.  Made three attempts without "bad" altitude behavior.  Strange but true.  It's been working fine ever sense.  I guess 'Quadcopter heal thyself" is a hidden flight mode we didn't know about  :>)
    • MR60
      This problem was already present in 3.2.1 as you can follow here:
      http://diydrones.com/group/arducopterusergroup/forum/topics/buildin...
  •  A bump on my problem of 12 hrs ago.
    I see that the altitude drift after  initial  boot isn't reset on arming. Is there something new there?
    Yesterday, I took off from +3m and landed at 9m. This would affect autoland. (in this case I did a manual land.
    WHen I tested on the bench, the altitude read near 12 meters after only about 5 min. It didn't reset on ARM.
    This last test was indoors without GPS, however a similar result occurred previously outside with HDOP of 1.3
    Anybody know what's going on?
    I'm going to fly today. I'll try letting it "settle down", then reset power, its shouldn't deviate much from zero on the ground, but that's not a reasonable fix.
  • Hello @ll,
    sorry if I overread the solution to my problem but I still cant find it in any forum. I have a PX4FMU + IO and APM 3.2.1 runs fine on it. I can upload to 3.3rc4 with mission planner but then I cant connect anymore. I'm trying APM Planner2, Mission Planner and qgrountcontrol. None of them connects. Just a timeout. I also tried different speeds but it doesn't work. I can then go back to 3.2.1 and everything works fine again. Does anybody have an idea how to solve this?`I see people running 3.3rc4 on PX4 here in the forum...
    Thanks and greetings from Austria
    Gerald
    • Hi
         I have done autotune with v3.3 r/c4   twice now and notice that rate P and rate I are identical in roll and also in pitch,  (5 decimal places ) coincidence?, part of the algorithn ,or bug?
      any way my Y6 flies so sharp and crisp now I am very pleased Thanks all.
       Tim Painter
        Hi Tim,
        That is part of the algorithm.
        Glad you are happy with the results!!
        • Hi
              Yes i think auto tune is truly sorted now.   just one thing after autotune completes I land with autotune selected and as soon as the legs touch down  the tri (y6) copter does a bucking bronco act, finaly fliping before i can disarm . This has happened every time ( thank heaven for soft grass) normal flight landings are easy(stabilise)
             Any way Thanks again for working on v3.3
          Tim
Aug 25
