Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I attach a link to my dropbox:
https://www.dropbox.com/sh/dnarxid3xychq1u/AADKFswaADCzTSE_uCl6Eupq...
Thanks for going into this.
Gregor
Hi Gregmaan,
I would encourage you to set these parameters
MOT_THST_BAT_MAX,25.2
MOT_THST_BAT_MIN,21
MOT_THST_EXPO,0.8
MOT_THST_MAX,0.95
These are the parameters that linearise the lift of your props and ensure your tune stays right as your battery goes flat and as you increase and decrease your throttle.
I will need more logs of your autotune on roll and pitch before I can help you further. I can tell you that you don't expect your roll and pitch pids to be the same on a hex though.
Hi Leonhardt,
I made some autotunes with your recommendations. With ATune 0.1 now I got an instabillity on roll and the same hard vibs from the motors espacially 5 and 6. Then I did it with Atune 0,8. I had still vibrations but only in stabilize. Then I reduced all values to a value there I got only small vibs on the motors. Sorry but your recommendations did not work for me.
I attached the new logs on Dropbox:
Further help would be fine ;-)
Cheers
Gregor
Hi Gregmaan,
That is very strange. That autotune did not work well. Your step responses during autotune are not what I am used to seeing.
You can drop the aggressiveness down to 0.05 and try again but the next step is to remove the gimbal.
Maybe you are interested in other logs:
Tarot T680Pro with 4010 340KV motors on 6S and 13 inch Props
Autotune_aggr 0,07. Much to sensitive, overall vibs
Autotune_aggr 0,05.Looks nearly good, but needs manual tuning.
The corresponding Yaw with 0,1 looks perfect !
I put some additional logs into the dropbox folder ...
Now I tested 3.3 Autotune with 3 Copters and would day there sould be some more steps avaliable to adopt the basics to do a good autotune.
In my personal case (T960) I am still tinking of an parameter which adopts the rpm lag to the pixhawk before doing autotune.
With autotune 0,06 on T960 there is still a bigger differnce between roll and pitch.
Cheers Gregor
Hi Leonhardt, thanks for this information. I think in my case its the ESC Motor combination. I did an autotune with aggr 0.06 on roll/pitch an it looks not bad without much wind. May I ask you what parameters are responsible to tell the FC how fast the props can react on throttle changes. Maybe I should set this values to the upper/lower limit. My pankakes react a litle bit slower than in "normal" setups i think.
Thanks a lot,
Gregor
Hi Gregmaan,
I have a 5 kg to 10 kg 960 that tuned on Autotune and will fly perfectly well with all up weight of 5 kg to 10kg.
I also have an 850 Quad that also tuned well.
I think the only thing that might be different since I tuned them is the Stab P may be higher.
I will go over them again this weekend and get back to you.
You will have to ask Marco about his copter.
I would also suggest you set the Autotune_aggr to 0.05. Looking at your logs though, this would not have helped.
Your s900 does not appear to be an autotune log.
Hi Leonhardt,
Ok, I will remove the gimbal and do it again with aggressiveness of 0,07 in the first step.
Today I did another autotune with a DJI S900 of a friend with the same strange behavior. I also put this into the Dropbox.
Are you really sure that autotune is useable for large Hexas?
Maybe you can talk to Marco R. who published a video of a perfect flying S900.
Do you know if he gets his perfecly flying Copter by using autotune?
Cheers
Gregor
PS: Maybe it is possible to get the params from Marco, for basic settings on S900
My initial results for 3.3rc4 - Tarot650 frame, pixhawk, ublox m8n, 700kv sunnysky motors with 12x55 CF props
Keep up the great work, it's getting even better every day
