Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • You mean you dont have the 29 option in rc9?
      I think the problem is a not a up to date Mission Planner.
      Just update, or manually type in 29 for rc9
      • Bjørn
        Thanks for your reply. I don't have the 29-option described under RC9, but like you mention, I can manually type it in. However I don't have the option for "Landing gear" under "Extended Tuning":
        http://copter.ardupilot.com/wiki/%20common-optional-hardware/landin...
        Like the procedure describes, I'm supposed to choose "Landing gear" at "Ch7 Opt" or "Ch8 Opt".
        Best reg.
        Eirik
        • Hi Erik, just set ch7_opt or ch8_opt manually to 29, I think until 3.3 goes gold then MP doesn't pick up the new parameter options.
          • Fnoop
            Didn't realize that I of course just can set that option also manually to 29. Sorry for all the trouble, and thanks a lot for all the help.
            Best reg.
            Eirik
    • I have landing gear working in 3.3-rc5. I believe your issue is down to mission planner rather than the firmware. MP does not yet have the 29 value available under the RCn_FUNCTION parameters in the Full Parameter List/Tree screens. You just need to set 29 manually against whichever RCn_FUNCTION value you have chosen to use. It allows this value and works fine once set. Hopefully a future version of MP will include this value.
      • Paul
        Thanks for your reply and your explanation, but like I mentioned to Bjørn, I don't have the "Landing Gear"-option under "Extended tuning" when choosing "Ch7 Opt".
        Best reg.
        Eirik
      • Yes I had to do the same thing - set RC9_FUNCTION manually to 29 - and it works great.
        Does your landing gear go up automatically after takeoff?  The wiki page says it should but it doesn't for me, and I couldn't see anywhere obvious in the code that would make it do so.
        • I think Randy mentioned that if you had a 3 position switch, middlepoint was some sort
          of auto, but what it do i have no clue. Havent tried yet
  • Hi
    ublox GPS is not detected when i tried 3.3 rc5 on px4fmu+px4io. Works ok on ac3.2.1 though.
    used 3dr GPS + compass and quanum GPS + compass both not detected on 3.3 rc5 but detected on version 3.2.1
  • Yesterday I flashed the V3.3-rc5 to my PixHawk hexacopter, but now I can't get to download the log anymore.
    In the MissionPlanners (latest version 1.3.28) CLI it only gives "mumbo jumbo".
    In the beginning it says:
    Waiting for reboot
    Opened com port
    3Initialising APM...5? (NO mention of Arducopter 3.3-rc5)
    Then the mumbo jumbo starts.....
    What am i doing wrong?
    btw Arducopter V3.2.1 gave no problems.
