Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Paul,
Download the Log via Mission Planner Terminal does not work anymoe from 3.2 and upwards.
In Mission Planner go to FLIGHT DATA and sellect "DataFlash Logs" under the HUD screen.
Than click "Download DataFlash Log Via Mavlink".
Hope this helps.
Geert is correct but I didn't understand how Paul said " Arducopter V3.2.1 gave no problems"!..
The last release version that used the terminal to download the logs were 3.1.5. Terminal removed after that.
AC 3.2.1 should be same as AC 3.3 rc5 as far as the log download is concern.
anyone tried out storm32 and tower at same time ?
my tower goes crazy ...
https://youtu.be/KzHd5ndXE84
It's probably because tower is picking up all the mavlink messages from the storm32 and not filtering them out. If tower has an option for specifying a particular system id and component id then try setting them to 1 and 1, if not then it probably needs a bug/issue filed against it.
I had the same problem with teensy telemetry and had to recode it to only listen to mavlink messages from a specific system/component id.
In the full parameters list the options for setting serial 4 protocol and baud are missing even though the second GPS parameters are included. When will the serial 4/5 parameters be added back to enable secondary GPS module use? Or is there another way to enable this that I am unaware of?
A second GPS is critical for UAV Outback Challenge operations, especially on small copter frames where RF separation is difficult.
Regards
JB
Autotune 3.3 rc5: frame x8 motor U5 propellers 16"+17" weight 9 kg (4 autotune, 4 different results)
Hi Antonio, what were the other results?
Hi Leonard, I found this .param that I have saved but if you need I have all the logs
In the logs I have many errors: "APM Speed Error", and warning: "Warning: UAV is struggling to maintain desired altitude"
pid1.param
@ Leonardthall What do you think of my pid?
