Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • @Leonard
    Attached is link to Auto Tune files. It seems to be pretty good, but while using Follow Me, it over corrects quite badly when pitching. Maybe that's normal?
    quadcopter
    KDE 515 motors
    APC 14x4.7 SF props
    650 size frame
    16000 mah 4s battery
    AUW 2.7kg
    Thanks.
    https://www.mediafire.com/?7a8co2555u7mjts
  • re- b) smart battery support
    Could anybody elaborate what this does and how it works?
    • Smart battery like the new 3DR Solo has. It's basically a normal battery with the 3DR Power module built in, but also charging circuits and fancy indicators showing battery capacity and so on. The battery communicates to the pixhawk with i2c i think (or another one of the protocols), so support had to be added for it.
      I'm hoping 3dr will release a mounting bracket of some sort so that we can use the Solo batteries in DIY projects.
      • Thanks. Boy that seems like a waste to have a power module inside every one.
        • There was a photo here somewhere of the internals of the battery, it looked almost like a DJI one (i mean that it had chipset taking care of all the charging and leds and so on as well as battery info back to the controller). Wouldn't be to hard to just take the Solo battery apart and have some extensions for xt60 and balance plug, and just use any cheapo battery from hobbyking.
          I can't find the photo of the internals, but here you can see the prongs that do the actual battery connection, and the middle pin might be something like a USB with multiple copper lines for data...
          • I really hope it is possible to take the battery case apart and solder in a new battery. You can't do this on a DJI they intentionally go out of their way to make sure the circuit sees this intrusion  somehow and renders the unit / battery useless. The 'smart battery' is mostly for revenue generation for DJI I think. My brother lost a phantom because the stupid battery wigged out and thought it was low and landed itself in a lake. Meanwhile it was fully charged before flight and his HUD display clearly showed an %80 charge remaining. I also heard they automatically discharge themselves aka 'storage' after a certain amount of time with no use. So you finally get time to go fly only to discover that fully charged battery isn't anymore. Or maybe you don't realize 'IT' discharged itself and you crash because you didn't realize it did this. Anyway.... I'm no fan of a 'smart' battery I have a brain and a charger I've been fine with it I don't need any help. If the solo battery is like this I'll not be buying a solo for this reason alone. But... I do like how it just plugs in. Very nice.
  • I did Auto Tune on rc5 again yesterday trying different props and larger battery with AUW 2.7kg.
    The stab roll/pitch seem quite diverged. Also, is it normal to see Rate Yaw  D value of 0? I notice when the quad takes off it yaws a few times before settling to the heading.
    One more question. Does lowering the roll/pitch sensitivity help with Follow Me mode?
  • Testing 3.3RC5 using PIXHAWK and latest mission planner Beta: Flight modes have disappeared!
    I mean the "drop down boxes" letting you select what mode for various value of channel 5 aren't present any more.
    I think it is a MP beta problem as re installing latest stableversion (1.3.28) did fix the "undocumented feature"
    Henri
  • PID Help..?
    I updated the firmware on my QAV 540 to 3.3rc5 and did my first test flight yesterday.   I like the audio tones for feedback that have been added and the flight was ok, the PosHold was very steady on 11 SATS with  a HDOP between 1.9 -1.8
    It was a bit windy and it held position pretty well.  However, it was loose in the pitch axis, when adding throttle to go up or decreasing throttle to descend, it would get into a rocking mode like a seesaw.  not very extreme, and I only had to stir the stick a little to break it out. But it had a definite tendency to rock, also the yaw seemed too sensitive.   The PosHold kept the heading very well, but when in stabile mode, I had to work the rudder a little to keep a good heading.  Probably the wind was causing that.
    This is a heavy build, QAV 540 with extended arms, 380KV motors, has a tarot gimble for GOPRO, carrying 2 3S, 5100 MAH battery packs in series for 6S, the CG seems fine with my Gopro in the front and battery packs toward the rear.
    I assume the PID values need to be adjusted.  I don't have a screen capture of my current settings, I may need to post that before anyone can help me, but in general can someone tell me which PI value or values I should changing?
    Richard- Kd5zzl
      Hi Richard,
      To help you I need to know what size prop you are running.
      We also have some motor linearisation code in there that compensates for battery voltage drop over the flight.
      To get the most out of your copter you will probably have to do an autotune or a full manual tune. I can help you with either.
