Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Second time it happened since v3.3 and I am not sure if it is v3.3 related of I have an other issue.  All in all, after landing (throttle minimum, altitude 0 - copter on the ground) when I try to disarm the copter (0 throttle,rudder left) two motors spin up causing the copter roll over (crash disarm).
    2015-06-06 16-55-06.zip
      Hi Robert,
      This is interesting. You were in Pos Hold at the time. That is the only mode I didn't have a major hand in designing. Does this happen in any other modes?
      I will chat to Randy about it.
      • I could not find the other log, when it happened first I thought I made a mistake with the sticks.
          Hi Robert,
          Thanks and let us know if you see it again.
  • This reply was deleted.
      Hi Lijingwei,
      This has two issues. The first is your copter is under powered. The second is your tune is not as stable as it could be. You hit the copter with a roll command and it then struggles to keep control. The act of decreasing some of the motors and increasing others means that it can no longer keep the average throttle high enough to maintain altitude.
      I would suggest reducing ATC_ACCEL_R_MAX and ATC_ACCEL_P_MAX to 72000 and doing an autotune.
          Hi Aleksey,
          I did mean 72000.
          From what I can see it says:
          Values: 0:Disabled, 72000:Slow, 108000:Medium, 162000:Fast
      Hi Jin'
      The answer to that question is always the last official release.
          I am interested to hear what problems 3.2.1 has. You need to be careful looking at the problems people are having because people tend to make a lot of noise talking about their problems but say very little after it is pointed out it was caused by a mechanical failure or setup problem. Our logging is so extensive that we can see pretty much exactly what the controller is doing at any given time. The only thing we really need to make educated guesses about is the external disturbances and mechanical/electrical problems. Maybe 1 in 100 basic stabilize/alt_hold issues turn out to be caused by problems with the controller now days.
          I would be interested to see a log demonstrating your problems as I have not seen anything remotely like this for years.
          I hope I can help you with your issues. I just need a log.
              Hi Jin,
              Well, it looks like you are right. It looks like you have completely lost contact with the GPS. From the logs I can't say if it has lost power or just lost the data link to the gps. I can't see any sign that your compass has a similar problem so that makes me think it is just the data link to the gps that has gone. (assuming you are using a 3dr compass/gps module)
              I would be checking my connector between GPS and Pixhawk. I would replace it if possible and try again.
              • Not once but twice I finally narrowed down erratic / inconsistant behavior to a stressed out DF13 connector. Not a big fan of those. But I have since used a dab of hot glue to make certain nothing can ever tug on those little wires.
