Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • MCU :Arm Cortex M4 @180MHz(STM32 F4 series). not too bad.
  • Hello everyone!
    Since the launch of the Arducopter3,3-RC5 , I have made more than 150 flights in normal weather conditions and everything
    was fine.
    1 - TakeOff is Ok,
    2 - AltHold is Ok,
    3 - Loiter is Ok,
    4 - PosHold is Ok,
    5 - Guide is Ok,
    6 - RTL is Ok,
    7 - LAND is Ok,
    8 - Disarmed after LAND is perfect,
    9 - Follow me is Ok,
    10 - SplineNav is Ok,
    Yesterday I decided to travel to the south of the country where I live, where the average wind speed is 25 km/h, observing the following:
    1 - TakeOff is Ok,
    2 - Loiter - Ups and downs of 2.5 meters
    3 - Guidance Mode - Ups and downs of 2.5 meters
    4 - PosHold - Ups and downs of 2.5 meters
    5 - LAND - Descent very fast as if collapsed (see video in the link's below)
    6 - Disarmed when it lands - not work when the vehicle was being subjected to strong winds (I could not disarm the vehicle because the thrust of the wind did not allow it , I had to remove the battery)
    Any suggestions for correct the above?
    Multirotor Specs:
    - QuadX 300mm Frame
    - T-Motor Air Gear 200 Brushless Motor (combo)
    - Kiss ESC 18A Electronic Speed Controller
    - Pixhawk Original by 3D Robotics
    - Futaba Radio T8FG Fasst transmitter
    - FrSky TFR4 Receiver
    - U-blox M8N GPS by VirtualRobotix
    - 3DR Power Module
    - 3DR Radio 433 Mhz Kit
    - Thunder Power 2700mAh 3-Cell/3S 11.1V ProLite + Power 25C LiPo
    Parameters that were modified to get good results:
    INS_ACCEL_FILTER =42
    INS_GYRO_FILTER =42
    www.youtube.com/watch?v=tfdURU2Gwiw&feature=youtu.be
    15-06-07_14-47-26.bin
    • Doesn't look like you have either LAND_SPEED or PILOT_VELZ_MAX set. I dunno whether the defaults on these changed, but my guess is that if you set them (or do a full reset on all your parameters) the problem will go away. Defaults are 50 and 250 respectively I think.
      • Hi Andy!
        I used the values of LAND_SPEED and PILOT_VELZ_MAX in 45 and 225 respectively for many years and not had problems with the landing.
        • I believe you, however they are not showing up in the log you posted. I wonder if they got nuked by the upgrade somehow. Can you try setting them again and see if they show up in subsequent logs?
          • At the moment, I have no propellers, but I made an order that will arrive in two days, I will test with values by default and then will let you know the results.
    • Hi,
      Hexa, Pixhawk v3.3 rc5 from 3dr.
      Wind speed is 10 km./h - it is OK.
      Wind speed is 22 km/h, landing is very fast  -
      - https://www.youtube.com/watch?v=2ie_ijwh_Vs
  • Compassmot on 3.3 rc5 work from mission planner?
    I tuning twice compassmot on THROTTLE (i off battery monitoring before compassmot) and i see on graph Interference (green line) always 50%!
    This is bug?
      Aleksey,
      It's more likely a display issue in the MP.  By the way, I strongly recommend using only the current based compassmot.  The throttle method is not very accurate and I was thinking of removing it completely.
      • Hi Randy! Thanks you for answer.
        I later connect current sensor and repeat calibration on Current.
        I yesterday tuning classic OCTO with 18x6.5 props with tune agressive 0.07. I wait 20min autotune and yaw finished. I manual land copter in autotune mode, gears on planet, i throttle in 0 on futaba and props NO STOP!!! I disarm - not disarm!!! I switched OFF autotune and disarm - disarm YES!  IMHO i landing and copter do it autotune.
        I sighed and wiped sweat from his forehead, but copter fell on its side. But thanks to the protection of props - no problem! But this is nonsense! And parameters avtotyuna not survived! :(
        If copter not finished autotune and i land in mode STAB and autotune and throttle in zero - motors is stop?
        IMHO in all events if pilot in STAB throttle 0 - copter off motors - required! The pilot knows better when to turn off the motors and the brain does not have it in this way.
        Ok. I told the assistant next copter flight to catch hold of the chassis. Assistant catches, I gas to zero turns off, but slower than 3.2.1, I do disarm. The parameters are preserved.
        Next autotuning i set autotune_aggr in 0.09 - in 0.07 very small angle test in roll or pitch and veeeery long time tuning pids. 20 mins for roll and pitch and yaw and yaw don't finish.
        1. In AGGR=0.1 copter stay 45 angles in roll and pitch and after finish flying good. But the presence of the unit swinging copter after a sharp rejection stick. That is, it is not immediately put into a plane after you release the stick, first at 15cm overcompensation and then in Level. You may need to add to D in pids on roll and pitch?
        2. Whether due to the low autotune_aggr increase autotune time and also because of the wind 2-4m / s?
        PS. IMHO need close ALL know bugs and later add new functionality.
        Most importantly - the reliability of the system. If the system is not reliable, it is useless, it is not necessary. I have thought to put on oktu Naza, but ... But I think I will adjust Pix. And on naza not good gps. On my pix GPS very good - 22 satellite.
