Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Randy,
      in addition to the log I provided - could you pls explain how exactly logic for super simple mode even works?
      How does it know where I am located with the transmitter? Why does it go crazy like that when it gets close to the operator?
      PS. on the response with a log I said - 'RTL did not do anything', I am not sure about it actually, but I think it actually drove drone right into my neighbor's flower patch, in the opposite direction from a proper startup spot, and it may correlate with same wrong directional inputs from the remote. but I am not sure. it all happened very quickly and as it started killing flowers with props I killed its motors.
        Paul,
        Sorry for the slow reply.  Super simple mode assumes the pilot is at the vehicle's home location.  I guess in practice the user is a few meters away from the home position but normally it's close enough.
    • hi, I was 'lucky' to get it on my first attempt, if you look at vibrations log there is a spike close to 3min mark - it is where it dropped on ground as all controls went erratic and I then killed motors, prior to that trying to do RTL that did not do anything.
      Pls advice if you will see anything in there.
      I then tried 3 times - and got nothing. 'super simple' mode is attached to channel 11. 'simple' mode is on channel 10. I did not see any issue with 'simple' mode during this test and after first incident with super simple mode it then worked fine on 3 subsequent take offs, close and far.
      1.BIN
  • Hi Leonard, Randy and Dev team,
    I was wondering what the value of ekfposhor should be in the HUD?
    Thanks.
  • Gentleman please see attached log from todays fpv flight.
    Pitch angle 55°
    Speed Peak 32m/s
    No significant vibrations
    AltHold perfectly straight
    Regards
    2015-06-17 19-24-36.bin
      Hi Pomaroli,
      Nice!
      Have you got some photos and specifications you an share with us?
      • Leonard,
        to make it really short, it is the common DJI F550 frame with Pixhawk Kit and Fatshark for FPV.
        The most important thing to know is that an antivibration mount has to be used, this one below works best
        3702705004?profile=originalAlso concentricity of Propeller mount is very important,  best is to use this type of adapter.
        3702704913?profile=originalIf more details are needed i can open a separate thread for it. Perhaps i'll do a tutorial next time i build one.
  • Hello you have any estimate for the next RC6 or 3.4 RC.x? thanks
  • Also,
    could anybody explain nature and a reason of why in the 'super simple' flight mode all controls suddenly may flip/invert or even worse - 'turn' 90 degrees? What is causing this? As sometimes it does not happen at all but if it does - it 'locks' into this and only way to get rid of it then is to disarm the drone and arm it back on, simple mode switch does not help.
      Paul,
          Do you have a log?  I had a peek back at a few of your post but don't immediately see it.  It's possible there's a bug in the logic although it works in the simulator ok.
          By the way, the vehicle must be at least 10m away from you or it won't update how the angles are applied.  We can easily make that area smaller but the GPS accuracy becomes a problem if the vehicle is very close.
