Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Randy,
    Flew my Y6B last evening just prior to a squall coming through the area.  Test was mostly in PosHold and Loiter to evaluate GPS accuracy and RC7.  Flight went well at low altitude so I pushed it up to 100-150ft and hovered her in the winds.  She preformed quite well.  After I landed I downloaded the logs and took a look at the vibrations.  Both X/Y and Z were well within limits but I when I zoomed into any particular area, I noticed approx. every second or so a dead zone where date dropped out for a very short period of time then picked up as if nothing happen only to drop out again a second or so later.
    Has this been discussed in this blog and if not, what is causing this to happen.  I never saw or heard any motor cut outs or irregularities so I think this is in the software side of things.
    I will later this evening post a screen capture of this and provide a URL to the log file.
    • Doug, this could be caused by your Dataflash microSD card not being able to keep up with the data rate.  For rc7, the dataflash rate has been increased to 400Hz, so we can gather more data on the EKF performance.  You should notice that the log files are also really big now. This is probably just going to be a temporary thing for rc7.
      This should be no problem for the flying ability of the system, it's just missing data log data.
      The standard microSD cards that come in the Pixhawk can't keep up.  If you want to see all the high rate data, you need a better dataflash card.  Apparently something with the UHS-1 label should work.  But even that seems a bit variable. Some brands work, some don't. I'm using an 8GB Adata UHS-1 card I got for just $7, and it seems to be able to keep up.
      • Thanks Rob.  I will look for a better performing micro-card.
    • What GPS is it? I have tons of Data drops on m8n units that are set to 5Hz. When I lower to 2Hz they go away.
      • This is related to vibration testing.
      • How do you do that? I mean, if GPS unit only has a single jack to connect to serial port on a PX4 - do you connect that directly to PC? What software then is used to adjust that?
        • I normally connect mine to a FTDI adapter and then use U-Center to make any changes then save it. You used to be able to press some keys in Mission Planner that would set up a passthrough which will allow you to connect via U-Center as well, but I don't remember the key combo.
    @Thomas,
    In case it helps, the speed up came from a change somewhere in the PX4Firmware or NuttX layer.  Peter Sidrane and Lorenz Meier were the authors of the change in case that helps track down the change.  I think it had something to do with disabling some memory violation checks.  Those checks were suprisingly cpu intensive but the change itself (to turn them off) might be quite a small commit.  This is all second hand information so I might have it slightly wrong.
  • Hi!
         At first,i can print someting in the tera term, like this:hal.console->printf_P(PSTR("distance_cm %d \n"), sonar_alt).
    Several times later, Pixhawk can't print anything with tera term or mp terminal interface. could you help me ?
      FlyToSky,
      This is a dev question I think so feel free to email drones-discuss@googlegroups.com or ping us on Gitter.
      By the way, "yes", that should work - if you're connected to the mission planner at the time it'll appear on the mission planner console window (see checkbox on MP's Help screen).  Alternatively the ::printf("distance %d\n",(int)sonar_alt) format can be used if you have a debug cable.  Debug cables are hard to get but you can make your own with a 3.3v FTDI cable plugged into Serial4/5.  This gives access to the "nsh console" on the Pixhawk but also display the output of the ::printf.
