Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Ok thanks.  So this is an item to fix!  We need to think of a way to not trigger the EKF failsafe in cases where the pilot isn't using a GPS at all.... perhaps we should only enable the EKF check after the EKF has initialised it's position estimate.  Issue raised here.
        • This reply was deleted.
          • Flew around a few meters to test roll & pitch response - copter always returns to perfect level.
    • With GPS (3dr ublox) detached i get bad compass health - no readings from external compass - perhaps powerd by serial port of GPS. Switched off GPS in params - no change in flight behaviour in stab and alt hold. Perhaps problem is caused by compass autodec (wrong or changing without GPS-Position)?
      2015-07-14 07-58-04 28.zip
      https://storage.ning.com/topology/rest/1.0/file/get/3702580216?profile=original
        Hubertus,
        great, thanks for testing!  It does appear to be flying fine.
        I totally forgot that the compass is powered from the GPS's 6-pin UART cable so if that's detached it won't have a compass anymore.  One way to disable the GPS in software only is to set GPS_TYPE to "0".  That'll basically turn off the software driver for the GPS which is good enough.
        • Randy,
          that´s what I did as you can see in param GPS_TYPE.
          The copter flies exactly like it does with GPS (and so EKF also) switched on - of course GPS-using flight modes don´t work.
          Many thanks for your great software!
          Hubertus
  • I have an odd problem after loading rc7.   I have a quad with a QAV550 frame, has 12 inch props, runs 6S with 380KV Tmotor's and have never gotten it to fly with a solid stability. If there is no wind, it flew pretty good, but I have been waiting for no wind to do an auto tune.  I updated the firmware from rc5 directly to rc7 over the weekend and now it is practically unflyable.   (I seems to have no stability at all in stable mode.
    I will include 2 flash logs.. the first is after flashing the firmware to the 3.3rc7 and no changes except for these settings:
    MOT_THST_BAT_MAX,25.2
    MOT_THST_BAT_MIN,21
    MOT_THST_EXPO,0.7
    MOT_THST_MAX,0.95
    I doubt that is my problem, because subsequently I reset the board to defaults and redid all the calibrations and setup, and when I tried to do a test flight, i was just as before, unflyable.. To define unflyable, I really couldn't get off the ground because it was determined to pitch forward, or back on its back. Both attempts, (before the reset, and then there flight several hours later after re configuring)  ended in the copter flipping onto its back.
    All the motors are spinning the right way and the props are on correctly.  It is as if I am trying to fly with no gyro, or accelerometers . I will attach the logs.  The 13.bin is the first flight on 3.3rc7 and the second 15.bin one is after I reset to defaults and redid my setup leaving the PIDS at factory.
    More about the copter:   It weighs 96 ounces 2.72 kg.   I'm set up for fpv with a go pro feeding video for FPV using 1.258MHZ. I am using a tarot gimble and of course the 3DR PIXhawk, early version.  I and using EZUhf on 433 with diversity, Taranis and using 915mhz 3DR radios for telem and a minumOSD,  I love the way it works when it is working!
    Any help figuring this out would be fantastic!
    13.BIN
    15.BIN
      Thanks for testing with AC3.2.1 'cuz that shows that it's really a general setup issue rather than AC3.3 related.
      It looks like some kind of mechanical issue to me although it's hard to say what the issue is.  Maybe an issue with the back left motor or esc but it could be ESC calibration is required, one motor is not starting, a connection to an ESC is broken, prop or motor spinning backwards.
  • Here is the logs from our crash 2 days ago. Again, after yaw input both rear motors turned off and the quad tipped back and landed on it's props. It is quite a large quad.
    Thank you for the help!
    https://www.dropbox.com/s/2e1n156dd1x36l3/2015-07-11%2017-04-45.bin...
    2015-07-11 17-04-45.bin
    Shared with Dropbox
      It's most likely a mechanical issues - I'd guess the THR_MIN is too low, one or more of the ESCs needs to be calibrated or an ESC sync issue which allowed one motor to stop.
      It doesn't appear to be an AC3.3 firmware issue unless it's a very low level issue.  Have you tried it on AC3.2.1?  It's best to do this especially if it's a new vehicle so we don't muddy the waters with AC3.3 issues and new vehicle issues.
      • Hmm, that's quite interesting. I will test with AC 3.2.1. So I assume the vibration and clipping issues look acceptable than?
        It is a 1300mm quad running 28" props. ESC's are KDE Opto's so there is no calibration of them, just set the min and max pwm values as specified in the wiki.
        Thank you for your responses! Much appreciated!
