Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Andre.
      Yes, as you suspect using ch6 to "tune" the wp-speed will overwrite the do-change-speed command.
      There are a couple of to-do items (here, here) on the issues list to allow setting the speed-up/dn but just haven't gotten to it yet.
  • Hi
    My pixhawk accel calibrates fine on 3.2 but refuses on 3.3rc8.  Could this be linked to the acceleration sensitivity being increased?
    Gareth
    • Anyone able to advise on this?
  • Just thought I'd give a shout out to the Dev's of 3.3!  A solid day (so freakin' tired!) of mapping for contours and volumetrics.  My mapping X8 is solid as a rock.  25kph winds and going strait as an arrow.  Still a few issues with the geotagging, but not a bit problem using Pix4d and a 90 degree kappa adjustment.  Best flying mapping drone yet.
  • I have not been able to download log files via Mavlink or even terminal IIRC since day one on PIxhawk. It always pops up "Error receiving log list". I have gotten so used to pulling the sd card out and getting the logs it kind of became normal. Would erasing the sd card and reloading the firmware fix it?
    • I see this when there are too many log files on the card (>50?). You might want to try removing some if this is your issue.
      • Well it does have over 400 log files :)  Guess that makes me a log hoarder.
        But the AUAV-X2 has over 200 and works fine.
        Seems like the Pixhawk has always had trouble pulling logs via MP though. I may format the SD card and reload, but will first clear out the log files.
  • This reply was deleted.
    • T3
      Hi Wilson,
      just a short note for now:
      your copter has pretty high vibes (up to 80+) and the accels are clipping - in both logs. So you should look into vibration damping. Unfortunately, the wiki page with some more details (http://copter.ardupilot.com/wiki/ac_measuringvibration/) is currently down.
      Attached you find two screenshots based on the raw data.
      Best regards,
      Thorsten
      Vibes
      3702584017?profile=original
      FFT
      3702583786?profile=original
      • T3
        This should be an interesting log for the devs because it seems on the edge where the EKF might run into problems.
            By the way, the error Flight-Mode-15 is because you're trying to switch into AutoTune from PosHold flight mode.  You can only enter AutoTune from AltHold.  We could change that, but that's how it is for now anyway.
