Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Luis,
It shouldn't be possible to get into Loiter while the vehicle is armed without a good position estimate. If you have a dataflash log I'd like to have a look at it.
Thanks very much for testing in any case though.
Here is my latest 3.3rc9 log
yes it is a tricopter and here is the bird:
yaw is better than with rc8, but still much worse than with 3.2.1
p.s. disregard clipping, this is due to unintentional touch-n-go-es :)
my only concern is that for some reason all of my logs have "shifted" vibrations.... to be more precise vibrations are not under +/-3 with center at 0, but +/- 2 or less with a center at 1-2 for x/y
Had my first with RC9 this morning, was very stable in moderately windy conditions. Alt-Hold, Pos-Hold, Loiter worked very well. Landing gears were functional running it through the Pixhawk. Telemetry to the Taranis was an awesome addition. Total flight time with autotune was 25 minutes. Had switches setup for RTL and Land and those worked fine, I also had a switch for simple mode and that is a very nicely added bonus. Thank you for giving us the ability to use all the additional channels on the Taranis, I'm using 14 channels through S.Bus.
Great work guys!
https://youtu.be/ZSzgQAV6TGY
Did you have to set the serial 2 protocol to 3 as mentioned above in red? I'm still on 3.2 because I couldn't get my taranis script to run right on 3.3. Maybe it's fixed??
Well RC9 is really good at first sight.
On a small 500 millimeters quad without even trying to adjust anything such as accel calibration or whatever from RC8 it is a dream!
It just works the way it was supposed to! Beautiful!
Have a look at the attached very short flight vibes with all flying modes I'm using.
Will load today RC9 on a much larger hexa and will give it a good test.
Congrats to the dev team for such amazing release.
Henri
it does not seem to matter what is in those flags. set battery failsafe for your voltage and see if it triggers on correctly, after pre-arm checks completes.
mine worked fine.
is your x2 modified with a "resistor mod" by any chance?
mine is not.
in my opinion this 'mod' is very problematic as contact patch for soldering there is way too small for a mass of a typical non-integral resistor and it is just asking for a future trouble.
I flew with RC9 yesterday and have to say if is far more vibration resistant than RC8 was!
I know my quad is not the greatest example, but as it has issues that show up readily it is a good example of the softwares tolerance to user over sight.
Yes, I have ordered some of the HK orange foam and found that I have 2 motors with signifigant bell play, maybe the cause of the Z issues I have been having.
I have been having problems with uncontrolled climb out when ever speed increases with with both 3.2 and 3.3r8.
Yesterday with 3.3r9 I was able to fly as fast forward as the quad could go, right to the point of not having enough power to maintain altitude with out any uncontrolled climbing!
The quad was flying well enough to run an auto mission which worked with out any noticeable issue.
Loiter was better and alt hold also.
Attached is a log of both and RC8 and RC9.
2015-08-20 21-32-53 5.bin
2015-08-12 17-13-06 9.bin
200
201
202
203
204
of 449 Next
