Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Yes Rob, I most definitely am. Before I made some Rate Yaw changes suggested by Randy I was experiencing a persistent wandering yaw even in Stabilize.
      Here are the changes I made per his suggestion:
      Rate Yaw P: 0.2 -> 0.3
      Rate Yaw I: 0.02 -> 0.04
      Rate Yaw IMAX: 100 -> 200   (it's strange how MP seems to be scaling this value, the raw parameter RATE_YAW_IMAX should increased to 2000).
      I will read through your Tri thread. I had been checking the APM Forum but I will have to more carefully watch threads here as well. I am happy to test specific things or even try small code changes and run local builds if that would be helpful at all.
      Cheers,
      Patrick
  • Hey today we had a flight crash with the Navio version of AC3.3-rc8. We had come software panics with the compass and the ArduCopter-octa-quad not starting on bootup. It was spurious and sometimes the APM started.
    We did a first flight where everything went well. On the second flight, the one where we had the crash, we had a first sign that things were not good, when the aircraft suddenly changed attitude about 13 seconds before the event that resulted in the crash.
    The pilot tried to slowly bring it to the ground so as to land it safely, but the aircraft again changed attitude fast and started moving horizontally in a slightly oblique trajectory. The logs are not perfectly formated because the battery was ejected upon touch down, immediately turning off the Navio.
    In the logs we have not observed any unexpected compass swings in the last moments of the flight, but we did notice a significant divergence between RCIN and attitude. The mode we were in was Stabilize
    The first flight log is 23.BIN
    The crash flight log is 24.BIN
    I also keep a file which is a mavlink dump of the secondary telemetry, don't know if i really helps. ard.log
    We also recorded a bit of video. In the video you can see the slight attitude change around here:
    https://www.youtube.com/watch?feature=player_detailpage&v=VwzYQ...
    And the moments before the crash the attitude change is:
      Paulo,
      Great that you're testing the NAVIO board.
      There's some very bad performance numbers in the log.  It appears that twice during the flight, the main loop locked up for a stunning 0.18 and then 0.21 seconds.  The first one of these happens immediately before the twitch.
      3702587705?profile=originalSo now the question is why is the main loop locking up for so long?
      Are you using a binary from our build server or is it something you compiled youself?  Is there anything else running on the board?
    • The logs did not go and the edit did not allow to re upload them.
      23.BIN
      24.BIN
      ard_log
      https://storage.ning.com/topology/rest/1.0/file/get/3702586951?profile=original
  • This reply was deleted.
    • In 3.2.1 default was 2.30(230), now it is 1.40(140).
  • Hi all,
    I have some issue with my new X8 and I am not sure the problem arise from the code or my build. First of all, sorry about I am running AC3.2.1. In short, my X8 will flip over when braking at position hold mode(loiter sometimes). Luckily, the X8 can recover itself just after the flip, so it won't be a mechanical issue.  I noted that every time before the flip over, the output of motor 1 reach its minimum, not sure it is relevant or not. I wish someone can help to solve this problem. Thanks very much.
    Best Regards,
    Isaac
    2015-08-09 22-17-08 8.bin
    • Hi, you're in the 3.3 beta testing thread.
      You are not running 3.3, or beta testing, so you should ask your question in another thread.
  • I had a couple good flights with RC8, I decided to hook up my landing gears up to the Pixhawk the other day, the landing gears worked as advertised, I also changed some of the flight modes around and that's about it. I did a test flight Wednesday morning and as soon as I took off it starting spinning clockwise. Wouldn't respond to Yaw or pitch and roll. The only thing I had was throttle, so I landed it. I thought I might have been my transmitter so I rebooted that and same result.
    Later that evening I calibrated everything again and still the same. Not sure what else to try. I attached some logs if anyone wants to take a look. I'm still not sure what I'm looking at when I look at the logs...
    badFlight.log
    badFlight2.log
    • One of my uncontrolled yaw cycles had the same thing happen I could not counter the spin or control direction, but was able to land.
    • Probably not your issue but on the same topic…. I had an issue where my quad would yaw turn very quickly one way but not the other. It was so bad it was not flyable. I finally discovered two of my aluminum amrs were ever so slightly twisted and as Murphy’s law would have it the same direction. So the other two motors simply couldn’t compensate enough. I was very surprised at how little of a twist in the arm it took.
