Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I don't suppose those nice features will be in APM Planner for Mac's will they? Is a lot of what's needed for that with the GCS software itself too right? aka Bill would need to work with you guys on that for APM Planner? Sounds like a great visual way to get an idea what's going on!
Richard,
They should go in for AP2 as well. I've certainly raised issues for the EKF and vibe monitors to Bill Bonney and I know he was looking at them.
Excellent thank you!
I'm also getting this on 2 different v2 Lites. It happens with only using the internal compass with low offsets.
I'm setting up the following tests over the next day or so using my old beater quad. It is an old wood frame 300 class with 30a escs [cheapies] and dji style 2212 920kv motors. using a cheap ebay AV mount, a v1.0 power module and a telemetry radio. 4 cell 2200mAh battery
2 v2 Hawk Lites.
1st test is both on AP 3.1.5 with m8n GPS and compass
2nd test is both on AP 3.2.1 with m8n GPS and compass
3rd test is both on AP 3.3-rc9 with m8n GPS and compass
I plan on doing an auto tune on 3.1.5 and enable full logging. Then run it though the flight modes
once done I will do a console reset and then flash to 3.2.1 and repeat the tests above.
since console goes bye bye on 3.2.1 I am not sure how to do a reset but will then flash 3.3-rc9 and do the same tests.
Then I am going to swap out the Lite for the #2 controller and do the exact same set of tests.
I'll have my hatcam on so I should have both full logs and video for a comparison.
Hopefully with a base I can offer up the data and hopefully see if any of it is useful :)
Hello
has just I made a new quad, gave new engines TM 4006 380kv and propeller TM 15/5, all on Pixhawk and Ublox M8N, total weight, with battery, 6s10000 mAh came 2600gr, I hover at 30%. Ive loaded the latest soft 3.3 RC9 and ran autotiun, the effect is not very good in the axis of pith in stabilize, very dangerous overshots in the roll axis is better but also swings, poor wind resistance, What did I do wrong? I set the parameter MOT_THST_EXPO, at 0.75 introduced the max and minimum voltage parameter AUTOTUNE_AGGR, I left unchanged ie 0.1. I enclose a flight log
LOG
Log.bin
Lukasz,
So like it mentions in Note #1 of the discussion header above, could you give the vehicle a fly with AC3.2.1 first? That will allow us to separate the vehicle issues from the firmware issues.
Hi, this is not the new quad, I changed engines and propellers, FC Pixhack flew from AC 3.1.5 successfully on old engines and propellers 12 " on 3.3 rc5 had the best flying quad so far. The propellers 15" also flew but earlier on AC 3.2 autotiun always gave convulsions, and had to reduce pids. Relative to old construction quad applied the other engines TM 4006 380kv propeller remained unchanged, I did a test on a small propellers 13 'and quad flew almost perfectly on the basic parameters change on target propeller 15 has caused these problems. That's why I was hoping look in the log, and advise me what I have to change in the settings to autotiun gave as good results as on propellers 13 ".With the new engine / propellers quad is flying nearly 60 minutes.
In summary, I have no errors, everything works properly, tests AutoTune to check the progress of the new version on different configurations, except for that matter to check the operation at the largest possible number of different configurations
Best regards
Lukasz,
I had a look at the logs and although I'm far from an expert on tuning, it seems to be controlling it's attitude very well. I haven't checked all the parameter of course but the main ones like THR_MID seem to be set correctly.
It's quite a powerful copter so perhaps the Throttle Rate or Throttle Accel P and I could be reduced a bit.
The vibration levels are a bit higher than my IRIS but still mostly within the acceptable range and there's no clipping happening.
Nice long flight time by the way!
Hi, thank you very much for checking the Log and for advice. I will try to play with the parameters Throttle Rate, or Throttle Accel P and I, and carried out again autotiun. Not only gives me peace parameter MOT_THST_EXPO I do not know how well that it changed from 0.5, propeller 15 "supposed to be 0.70 is 0.76 wrote DEV LeonardtHall, but these engines are very light weighing only 66gr while standard engines by a propeller weigh from 90 to 140gr even weight gives the inertia and here it is much smaller, on the other hand it gives a torque. Do not know if this parameter has a significant impact on the property and behavior on the fly whether to give 0.5 standard and only play with the parameters Throttle?
Best regards
Hi today I let the autorun again, I updated to AC3.3 rc 10. In the platform, added gimbal with GoPro, I lifted the weight change a parameter, THR_MID to 32%, and MOT_THST_EXPO changed from 0.75 to 0.65. After these changes finally my kopter is flying like a dream, ended overshoot in the pitch axis, you will see that it is doing nicely in the wind, the sensitivity rate is much higher than previously set. Super soft great job !!. I enclose log
LOG.bin
191
192
193
194
195
of 449 Next
