Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Alex,
      I think decreasing ACC_PNOISE may be best.  Increasing both EKF_POSNE_NOISE, EKF_VELD_NOISE together seems reasonable to me.
  • This reply was deleted.
      VP,
      It looks like a failure of the front left motor (#5 because you're using a hexacopter in the plus configuration) to start properly.  It displays the classic signs of a motor failure, the actual roll/pitch separates from the desired suddenly and it rolls left in the direction of motors #3 and #5.  In addition the output sent to motor #5 goes to maximum while it's opposite (#6, back right) goes to minimum.
      It might not be a straight up motor failure but perhaps the motor needs to be calibrated or it's settings are different from the rest.
        • VP, just curious. Were you able to control the Hex with one failing motor? Was it bad? How much thrust you need to hover?
    • i had almost exact problem before and it was driving me nutz...eventually i found out it was a motor going bad and having sync issues....it was very hard to figure it out....but check your motors/ESC for intermittent failures
  • I found some smaller issues with RC10:
    • RC deadzone settings don´t work for the serial RC control channels of the storm32 gimbal (RC6).
    • Sonar height differs after some flight time out of sonar range to the est. height. That leads to jumpy alt behavior commng back to sonar range.
    https://www.dropbox.com/sh/dnarxid3xychq1u/AADKFswaADCzTSE_uCl6Eupq...
    There is another autotune log in the folder.Maybe someone could give me a hint how to get lower PI values from autotune? Maybe it is possible to lower the autotune_aggr below 0,05?
    It´s a large Tarot T960 with 18" CF and 5010 pancake motors. The auw is about 6.x kg.
    Cheers
    Gregor
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Hi Gregmaan,
      0.05 is the lowest it goes. What exactly is your problem with the tune?
      • Hi Leonardt,
        my problem is still that the copter still reacts too much in windy conditions.
        With aggr of 0.06 the problem gets worse.
        This happens either in stab and loiter/pos_hold.
        This is an old case. Last time with lower RCs you told me that I should reduce some filters from 20 to 10 Hz (because of high frequency vibs at about 20 Hz.)
        But with RC10 and above this does not give the results as before.
        Maybe you can give me a hint? Does I still have the vibs at 20Hz? How can I visualize these vibs?
        Thanks a lot, and sorry for my poor english ;-(
        Gregor
          Hi Gregmaan,
          What do you mean by reacts too much?
          • Hi Leonardt,
            maybe overshooting is the right word for what I think it does? Or in other words maybe too sensitive to outer influence?
              Hi Gregmaan,
              Sorry but you will really need to go into detail if you want me to understand what you are seeing.
