Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Scott, I experienced this as well, when I build a copter for a friend who eagerly wanted this cheap FC.
It turned out, that the internal MAG wasn´t working although it showed up with its dev_ID @ MP. However, when I did Compass calibration, it didn´t really show up (MP claimed about 10 samples), so its really unsuable, although present.
Maybe, if there would be a way to turn the internal MAG off by AC, Variance message would not appear.
Nevertheless, since this PIXHAWK Lite V2 came up with random Bad AHRS as well, even sitting still on the desk and presented a SELF TILTING horizont (sometimes so that power leads have to be shorted), I m going to RMA this pos.. Maybe the builders used 3rd choice LSM303 (located right beside the MS5611)...and the next one is better.
Despite of that, it does fly ;-) (Well I turn off all PA checks anyways.)
@Alberto: USB is working fully @ the one I described above. Production Variance ;-)
Hello I just loading 3.3rc11 a auav-x2 and I have an error on the altitude (altasl) or what is the mutli task planner before takeoff?
3.3rc11 works perfectly on my pixhawk
Alain
Hi guys, here is a log for reference in case this is useful.
And sorry Randy, I know you generally only want to see frames that are already proven with 3.2.1, but I thought this one might interest you. It's a 400mm-or-so Y6 I have been having an awful time getting to fly stable. The experiment is to see how small a decent portable DIY photo mapping craft can be.
I have been unable to autotune due to significant drift in Alt Hold that I don't see in Stabilize, at least not as consistently. And it doesn't seem to be just CoG since it's not always the same direction. So I suspected vibes. Looking through logs, every one has z-axis clipping on the Vibrations 3.3 screen! The Pixhawk is isolated by 2 layers of Kyosho gel pads at the corners as an experiment. I may run out and try one layer quickly to see if it's simple as that.
What are your thoughts? Does it just look like an unstable frame?
2015-09-11 10-57-40.bin
Just try THIS latex foam it does miracles :)
I have a tricopter which I fly between the trees and tree brunches, well once after a "small" mishap which involved flipping and falling I was able to get the copter in the air without physically coming to it. When I finally flew it back to the base I was shocked to see that a good 1/3 of a CF prop on motor #1 was missing, yet it flew rather well :D
I go though a lot of props with my flying style and I like CF T-style props, I found a way to source those from china for cheap, but the problem is those are never balanced and with the foam I referenced I yet to have to balance one of those, no clipping and vibes are below 2 on x/y and below 4 on Z....
this Pixhawk is VERY well isolated using Kyosho Zeal pads at the corners. To be honest I'm pretty blown away that it flies so poorly. It's an Electrohub Y6, really neat frame with simple 1/2" wood arms. Motors are SunnySky X2212-980kv, battery is 4S 5000mAh at 523g. Out front is a gimbal with GoPro.
Since 3.3 has better accounting for vibes it seems like a good test case. The issue is I can't figure out where the vibes are coming from, potentially simply something with the frame assembly itself.
Here's another log. vibes on X and Y look fine, while Z looks just crazy.
2015-09-11 12-54-17.bin
One crash can cause play to develop.
The motor bell play causing Z axis vibration was mentioned as some thing to be added to the wiki, but has not yet.
Thanks for your suggestion - I checked the top rear motor and there was indeed play. So I have that resolved now. A subsequent flight felt much smoother. It still drifts away in Alt Hold with no wind, but it's possible that has to do with CoG. This one has been very tricky to balance.
Here's the log in case you're curious.
2015-09-11 18-17-13.bin
crayfellow,
Are you using a Y6 or flat frame?
For my Y6's, these scales make it very simple to get COG as perfect as it can be.
http://ebay.to/1K2fOH6
this guy is a Y6 (X2212-980kv, APC 9x4.5MR, 4S 5000mAh, gimbal/GoPro). I will take a look, thanks!
Try autotrim. Also, do you do acc calibration via telemetry or via usb cable? If you do via USB cable it can pull the board towards itself resulting in imperfect level calibrations. I do all my calibrarions via telemetry these days even if I am not using it while flying.
151
152
153
154
155
of 449 Next
