Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Hi Shaun,
          It is hard to say without seeing the whole tune. I would go with the first tune though.
          • Hi Shaun, what PIDs did you end up with on the T690. I think I'm running an almost identical setup to you with the 288kv motors and supreme 1865 props. The last tune I ended up with at aggr of 0.05 on RC9 was approx rate P 0.36 and D 0.022 Stab P 6. Running a higher AGGR led to high freq vibes on takeoff. Seemed to fly well with these PIDs but need to put it out in the wind more before I can be sure.
            • Yeah with my good tune, When I start the motors I get some shakes like you'd get with too-high PIDs, but they settle once it leaves the ground, and it looks very solid in the air.
              Hi Glenn and Shaun,
              You may have different brands or settings on your ESC's and different brands of props. This all has an effect on the Mot_Expo parameter and that may account for the different performance.
            • Funny, I couldn't get a good tune at .05.  At .075 and .1 the P and I was around .25 to .28 and the damping was .0133.  Stab P from 5-8.  I get the shakes on takeoff, but everything settles in once in the air.  Not sure why that's happening.
          • Here's the log files for two autotune flights at AGGR.05 and two more at AGGR.1:
            AGGR .05 flight one:
            https://www.dropbox.com/s/4kt10s3ioyhqqz2/AGGR05Tune01.bin?dl=0
            AGGR.05 flight two:
            https://www.dropbox.com/s/f00t7cwt7akyhwy/AGGR05Tune02.bin?dl=0
            AGGR.1 flight one:
            https://www.dropbox.com/s/nv7czrpy35bfins/AGGR_1Tune01.bin?dl=0
            And finally AGGR.1 flight two:
            https://www.dropbox.com/s/vsad4awhmwaz6b2/AGGR_1Tune02.bin?dl=0
            So the best two autotune's seem to be the first flight at AGGR.075 and the first autotune with the AGGR.1.  The ATC_ACCEL is quite different though:
            @ AGGR.075, ATC_ACCEL_P_Max is 41,681.06, R 49,677.57 and Y at 16,746.3
            @ AGGR.1, P 110,000, R 110,000 and Y 27,000.
            Is it strange that at AGGR.1 the ATC is has no decimal numbers with P and R both the same?  Kind of like when you do an autotune and get D number as the default was.
            Dropbox - Error
            Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
              Hi Shaun,
              The aggr is best when it is just a little bigger than the rotation rate noise you have on your controllers. It tends to be reasonably tolerant to small increases but if you go to small, autotune goes to low pids trying to remove overshoot that is really just vibration.
              I am glad you have got a good tune!!
          • So I did some more testing at aggr .05 and .1.  Wow, what a difference.  At .05 the tuning was useless.  At .1 they approximated my best tune at .075.
            First tuning at .05
            3702850779?profile=original
            Second tuning at .05
            3702850943?profile=original
            Third time with AGGR set to .1
            3702850800?profile=original
            And finally AGGR at .1 for the second time.
            3702851056?profile=original
            I'll attach log files for these.  Is this helpful for beta test?  Or am I wasting space lol.
          • The log files are two posts up : )  I'm heading out right now to try different values of AGGR with multiple tunes.  Should be interesting.  Wonder in the AGGR setting is linked to the size of airframe on top of dealing with flexibility.  In this case, even though it's large it's also a very stiff frame.  I'll run the full set on this, then to the 960mm hex and finally test out the 1300mm X8.  Good thing I have a lot of batteries lol!
  • Hi,
    Tested position hold and auto modes on rc11 today. The ROI is still not working, loaded mission with MP 1.3.31.7. This has been a problem with other AC3.3 RC's as well. After mission, switched to PH and landed, throttle down, and by mistake switched to Auto again, with throttle down left to dissarm it began to spin up again and ended on the side. Is this normal? Still a bit much altitude drop even at low speed. Otherwise nice performance. Thanks.
