Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi Shaun,
      This is because autotune sets them to be equal. This is based on the time constant the average pilot expects to see.
      • Am I the only one that didn't know that?
  • RC11 flies very well. I had frequent EKF issues, all resolved now. Thank you!
    3702097556?profile=original
    I have not seen any info regarding DO_MOUNT_CONTROL other than mentioning it in the wiki. I have wanted to use this for some time now, so I thought I would post a video showing my results. I did not spend a lot of time planning the mission and its not the greatest video, but maybe it will help someone. I am flying a stock IRIS+ with a tarot 2d gimbal, so pitch will be the only variable. In mission planner my gimbal is restricted to move between 0 deg and -90 deg.  If using a different gimbal, check the gimbal set up page to know the limits for this command. I initially tried a pitch setting of 20, and since that was out of the range of 0 to -90, nothing happened. When I figured out pitching down should be a negative number, it worked great. At the first waypoint the camera goes to -20 deg, followed by -25, -30, -35, and -40. I included the waypoint file is case anyone wanted details.
    https://youtu.be/bnjXxMpqgKI?t=43s
    I'll be using -30. Here's a large road project near me. This video ends showing a transition from DO_MOUNT command to ROI and back to DO_MOUNT.
    https://youtu.be/SVp7MN3sTg4
    mount test.txt
      Thanks for testing, nice video!
      • Thanks for developing!
    Copter-3.3-rc12 is now available through the Mission Planner's beta firmwares link.
    Desperately hoping that this is the final release candidate.  We received some complaints from others on the dev team that they were seeing a "Compass Variance" pre-arm failure which they could never get rid of without power-cycling the board so -rc12 has a change just for this one issue.
    If all goes well we will do the "soft release" of Copter-3.3 no later than next Tuesday.
  • Today I had a bad crash with RC11:
    I was flying smothly near to the ground. Suddenly the copter went wild going fast forward then left backwards. My control inputs did not respond to the Copter. So I shut down throttle, setting it with the camera on the ground. The objective of the camera is now destroyed, and some scratches on the display. I did not know what happens. Maybe someone could assist?
    https://www.dropbox.com/sh/dnarxid3xychq1u/AADKFswaADCzTSE_uCl6Eupq...
    (2015-09-21 14-54-28_crash.bin)
    Gregor
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Gregmann,Ok, thanks for the log and sorry for your crash.  As Leonard says this one is a GPS glitch - the logic for that is now in the EKF so PaulR also helped with the analysis of the log.  Some of the bits we discovered:
      • the GPS update rate dropped from 5hz to 2.5hz 19 seconds before everything started to really go wrong so there was some early indication that the GPS was having troubles.  It's unclear why the GPS update rate slowed, it could be a GPS power problem, I'm not really sure.
      • the GPS suddenly lost lock completely for 6.4 seconds which is unusual.  We'd expect it to jump around or report bad positions but to suddenly lose lock is a bit odd.  I will ask Michael DuBreil (our GPS expert) to look into this.  I worry that the GPS driver may have actually caused the loss-of-lock as it tried to speed up the GPS again.  That's completely a guess but something we will look into.  Another possibility is that whatever caused the GPS to slow, also caused it to lose lock.
      • The EKF handled the loss of lock fine, it was when the GPS recovered that everything went bad.  There are some things we can do to improve this:
        • EKF will tell the position controllers (i.e. Loiter) that it's glitched so the Loiter controller will reset it's position all at once.  This may have avoided some of the vehicle leans you saw as the Loiter controller tried to move back to where it was before the glitch.
        • add a GPS Glitch failsafe.  We need to discuss what the response to a glitch should be but Solo guys have chosen to switch the vehicle into AltHold mode until the Glitch has cleared.  We might support multiple responses like we do with other failsafe.
