Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • It's possible if a motor stops or is commanded to stop suddenly (particularly if you're using regenerative braking or 'damped light' esc mode, or if the prop has high outer inertia) that the momentum of the prop can continue and unscrew the quick release.  Quick release hubs are inherently unreliable, although very convenient.  One thing you can is to use PTFE tape in the threads, it should really help to guard against unwanted 'undoes' while still being easy enough to take off and put back on.
      • Thats pretty much the conclusion I came to. Was going to add a safety wire or pin hole drilled through the hub but balance is a challenge. Will do on the ptfe for the moment but suspect I may just remove the hubs. Two allen cap screws is not that much of a problem!
        • I came to the same conclusion - undoing/doing a few screws better than losing a prop mid flight!
  • so when is there going to be a official release? dont say when its done either how bout a date for once lol
    • James, we are attempting to please a great many people around the world, many of who have expressed their desire for a stable, problem-free release.  That was not just the majority, but pretty much a consensus of opinion.  This takes time to get right.
      You are of course welcome to use 3.3RC12 if you wish, which is as stable as an official release would be if we were to release today.
      I've had the flu for the past few days but hopefully soon-ish.
      • I hope that you get well soon Randy.
        Meanwhile, simple question :)
        If I change the value of INS_MPU6K_FILTER into: 5hz due to high vibration
        Is it affecting AUTO and other flight mode?
        Since default value (20hz or 0 ) make the THR pulsing extremely on take-off even when using Stabilize.
        Log file before the value changed, pulsing wildly on take off.
        Any advice perhaps :) ?
        Many Thanks
        Dropbox - Error
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
          Hi Waladi,
          This isn't a 3.3 question as that variable isn't in 3.3.
          The correct way to deal with that problem is to decrease your alt hold acceleration PIDs. I would suggest reducing them by 50%.
          • Upss... sorry Leonard.
            Noted, I post it on 3.2.1 topic
            Could you please check it?
            btw: the problem is not on the Alt Hold alone but in the stabilize also affected.
  • Can anyone tell me what 'locate copter' alert is about?
    Seems I'm only getting these since switching to 3.3
