Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I understand that 1 is the ext compass
i cant attach the log file, is too big....will figure another way
here is screenshot...the forum is acting weird today
The autotune was OK when it was finished, tried it for about 5 minutes.
Hi Alf,
Can you supply a log?
Hi!
You can download it from http://www.rappens.se/2015-09-28%2016-53-44.zip , 8 MB so it is to big to attach here.
I analyzed som more and I think it stopped and did some yaw back and forth some more times during the autotune?
Thanks!!
when will the official 3.3 be released i been waiting a long time.. i see 12 rcs
Kirk: you can get a try with carefull and returned to stab release if you don't like, for my last build, I have to solve some issues yet but this release is the difference to fly and no fly so no return for me.
Remember to save your params in case you don't like it it's easy to go back..
Dear James T Kirk,
I had some OT replays in this thread which were simply ignored, and I learned the lesson.
I am happily flying the 3.3 beta without any issues from RC9 up, with my setup, but some people did or do have problems, and I am pretty sure that if 3.3 was officially out and you had any issues with it, your anger would be all over the forums.
I learned a lot about the 3.3 simply by following this lengthy thread
So you can either be silent and wait for the official version like me, or you can contribute to the beta in any way.
Or you can ask Scotty to beam you up to the new version, or just switch to DJI, Naza or anything else.
The devs are doing a wonderful work so please let them decide when it's time.
Just my 2c.
Randy,
I have a unique testing situation where one of my PixHawks has a faulty Gyro2.
It's really all over the place, completely FUBAR.
It won't stabilize at all.
So I was glad that in v3.3, there was an option to disable Gyros.
Since I set "INS_USE2=0", I can now use this Pixhawk with only the single Gyro1 working.
However, the settings doesn't always work, specially during initial boot.
Most of the time when I plug in the battery, the second gyro is still having an impact, and I get all kinds of EKF, GYRO, errors.
I usually need to unplug the battery a couple times in succession, before Pixhawk ignores Gyro2 values.
My point is that the Gyro disabled function, should be before any Pre-Arm checks.
I haven't looked at the code, so I am not sure how it is now.
But Pre-arm, Nav checks, definitely still check gyro2 even though its disabled.
I also have my settings to skip INS Pre-Arm checks for this Pixhawk.
Allowing it to eventually arm and use GPS modes.
if you plan on making any code changes to how the INS_USE variables are used, I can test for you if its working, with my crippled Pixhawk.
Also I can confirm that EKF errors do recover better, as per the release notes.
