Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Make sure you don't have the problem I had - AUAV-X2 + ACPS3 give spurious current readings when the battery is not connected. This means that the MOT offsets will be applied even though there is no interference - leading to a very unhappy EKF when on USB power. Try setting COMPASS_MOTCT to 0 just to check.
I have tried 3.4 dev (master) and i have problems with compass calibration on Raspilot v1.1
i have a external compass connected as well as the internal (s).
Anyone else using Raspilot ?
I don't know if this is a Pixhawk problem or build problem but I can not get an acceptable compass calibration. I have done just about every method even spinning in an office chair. At the end of 20 minutes of spinning and 1700 data points I still end up with compass 1 with -931 613 -2655536 and compass 2 314 -195 -44 After restart I still have a double flashing yellow on the pixhawk, error compass variance in MP and a red EKF for compass on the HUD. This is with RC12 and the latest version of Mission Planner on a 2104 3DR quad frame and PDB with a M8N GPS/Compass from Ebay on a 6in extender.
Any suggestions or will have have to keep playing spin the chair with my son? He for one enjoys it.
Spinning in an office chair should be avoided because its steel and had disturbes the field. You should do it outside away from large steel objects(cars). Having said that, the numbers indicate that mag 1 has failed or has a huge interference. Try disabling it.
Oh boy that would suck if the internal compass was on the fritz. I'm sure that's not an easy fix. I tried the MAG_ENABLE option in Mission Planner and it disabled both the internal and external it appears. I couldn't get over 3 samples with it on and once turned off it would at least give points.
Dave, MAG_ENABLE is not the param you want. Look for COMPASS_USE in the full param list. You can enable/disable each compass. I haven't tried this, my compass works great and I found all 3 enabled and I don't have a #3 compass. I have never don a compass_mot cal. I just assumed I am using the external compass on a mast. If one has failed, turning it off could get you flying. Maybe I should do a compass mot cal in case I loose the primary compass.
Another thing I notice. I'm flying with only int compass until I solve ext one, I calibrate and all looks well but flying with Tower, in middle fligth without changing nothing flag EXF (great tool) becomes orange and red, then I do another fligth but with no Tower but notice in the two logs that offset changes, that's common? I never see in other logs. (one log is the same share.)
here the log
2015-09-26 10-23-27.bin
I test 3.3 rc12, It's looks much stable than 3.2.1 but I change many things to evalute exact difference, (controller, dampening system and firm). The only problem I still have is mantain altitude, I notice that repeat similar issue than the APM so, I hope I'm having mistakes tunning it, It's looks that baro overreact? which param work exact there? (with APM I try Throttle accel, rate and ALT P ) Thank's
Nick,
As you mentioned, it was dangerous in practice to allow people to arm and take-off in a mode that requires the EKF to have a good position estimate (i.e. Loiter, PosHold) without enforcing that that estimate is actually good. I don't think we can go back on that really so instead, if this change has made testing the failsafe more difficult perhaps we should just try and make that testing easier.
125
126
127
128
129
of 449 Next
