Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Eduard,
I can confirm what Randy said. This is definatly failure of the back right motor or ESC (#4). It may have been a low battery cut out but I think it is more likely an ESC or motor failure. One one of my personal quads I had a broken solder joint that caused intermittent crashes but on the ground everything worked. I would try giving a very solid pull on each of your solder joints on that motor/esc. The thing that tends to show up damaged windings on a motor is full throttle while the copter is held down or mismatched motor outputs in flight. There doesn't appear to be any sign of the problem leading up to the crash so I suspect that you will find this problem is something that is a good/bad situation with nothing inbetween.
So first port of call is solder joints and low voltage cut off.
Sorry to hear about your crash!!
What motors/ESCs? Could be loss of sync with the ESC if its a larger motor.
I'm certain Randy is right - 3 and 4 move in opposite directions at the same time and 4 is then dead. No way the FC can keep it level with only 3 motors...
Speaking of mini quads.
Anyone who's flying with mini-pixhawks or mini-apms.
Do you guys use any vibration damping, or do you just bolt it to the frame?
You DEFINITELY need SOME dampening regardless of what frame you use. I "used" to use a dampening plate that I made out of the top camera mount on my 250 frames but now I use This with double sided carpet tape and it works VERY well. Much better than I expected to be honest.
The orange foam is too thick for my QAV250. I use the neoprene foam that comes with the kit and that seems to work pretty well - on the mini quads the vibration frequenceis are much higher and seem to affect things less, so I don't think you need as much dampening as on the bigger quads.
Without any dampening on my 250's [I've built at least 1/2 a dozen now with 4 of them using APM Mini's] if I didn't use any [as in planting the APM down on the frame] I would get horrible ALT-Hold and Loiter modes not to mention such bad oscillations that it they literally flip on take off. One could say that it is less "important" on small frames more so because of the way they are flown [as in acro mainly] but my findings have been pretty consistent in the need of "some" dampening even on small frames. I'm betting when I swap out the APM Mini I have on my newest build with a Pixhawk Lite that it will also show the need for "some" dampening now that the EKF and Vibs graphs are available in flight. Since I am waiting on my Tarot T960 frame to come in and a rebuild of a buds 450 class quad I may take the time to swap out the APM for the Lite [god oh god the wires on both SO SUCK] to see. I guess I can mount direct to frame and test and also mount via the foam to test [I have both the white foam and orange foam]
Man so many projects so little time sigh. Good thing I love it lol!
http://diydrones.com/profiles/blogs/fpv-racing-using-arducopter
Randy / Devs
Can you look at my post about having a problem with SR params not staying to what I set them to work with my Taranis Lua script please?? I don't know if this is an issue with 3.3 or not. Please see my last two posts on this page... Thanks!
http://diydrones.com/forum/topics/copter-3-3-beta-testing?xg_source...
Hi, this has likely nothing to do with 3.3 and is better discussed in the telemetry threads or with the vendor you bought it from.
