Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi OG
I just checked to be sure. 3 channels are supported, there are even pretty pictures to setup in the GCS :)
I've used AC-Copter 3.3 with Storm32, Alexmos and three gimbals with pwm support only (Tarot 2d, Feiyu mini-3d, Zhiyun Z1-Tiny2).
Z1-Tiny2 is the most super awesome gimbal btw :)
Fnoop,
Any advice setting up the Z1 Tiny 2 in APM Mission Planner? What gimbal type do you select? (I assumed servo since that's the type of input that the tiny 2 would accept from a normal receiver). For whatever reason when I try to connect the input pins for the Z1 Tiny 2 to my Autopilot (driven by ppm from receiver) it just buzzes and doesn't care about what inputs I'm giving from my radio. If plug it in directly to the receiver it behaves like it should (slews to where I have my radio set to).
Thanks in advance,
Jeremy
Hi Fnoop and or Jeremy,
Did you have any result allready on the setting for the Tiny2?
I'm looking everywhere to find something about the wiring from my PixHawk to the Tiny2, but didn't find anything usefull yet :-(.
Only if you have a brushless gimbal controller between the brushless motors and the APM.
hi, is it possible to connect a brushless gimbal (not servo!) to my APM?
thanks for any help.
I reflashed all my ESC's (RCTimer 16A) to BLHeli 14.1 with damped-light, medium high from SimonK and now I get a serious wobble/vibration in flight. Is this just a case of needing to run autotune again or should I be looking for something else? This is a QAV250 setup. If it needs retuning what should I change manually to get it to a more stable place where I can confidently run autotune?
Hi Andy,
The motor breaking probably means you need lower Rate gains. I would say drop your rate gains until you don't get oscillation then do autotune again.
Hi Leonard,
Can you tell me which setting this is?
Thanks!
Hi Andy,
Drop Rate P, I and D for roll pitch and yaw by 25% at a time until you stop oscillating. And make sure Stab P is about 5.
I am assuming your wobbling is fast and not slow....
95
96
97
98
99
of 449 Next
