Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • An observation.
    Yesterday I tried Auto Tune. The copter would not hold altitude while in Alt Hold, which is commonly reported by many. The AT was aborted and I discovered the vibration levels had worsened.
    Today after improving the vibration levels by > one order of magnitude, during AT the copter held altitude much better.
    Confirmation bias or a connection?
      DG,
      Great that you got the vibes reduced that much.
      Bad vibrations will certainly affect AltHold performance.  It's absolutely critical and we recommend people designing/building copters to check their vibration levels (see First Flight section's Measuring Vibration wiki page) and the live vibration monitor added in Copter-3.3 was added to try and make doing this a little easier.
  • Leonard/Randy,
      If you get time, would you please look at these Auto Tune results for my latest quadcopter build? It's an H4 Alien 680. The props are APC 13x5.5 MR, smaller than desired, but I could not find the adapters for the 14".  It had one squirrely event during roll while AT, but other than that it went smooth.
    Why is the Stab Pitch and Roll so diverged? The COG is darn close, and it seems to fly ok, although only flew it for a few minutes in perfectly still winds :)
    Link to flight log
    https://www.mediafire.com/?rl6u4rqdx99c52x
  • Hello,
    I'm unable to use my tarot t2d gimbal with 3.3 on pixhawk. I have been using it connected directly to my rc on channel 6. Today, I setup the camera gimbal on mission planner to RC9 output / rc6 input according to the wiki. The gimbal initializes with the blue led steady ( no signal )  and the cam pointed to the front ( horizon ). When I press the motor switch , the blue light starts blinking and the camera turns downward, but I'm unable to control it with the RC6 switch.
    Could someone confirm that it is working with 3.3 version and perhaps point me to a soution?
    Many thanks in advance
    2015_10_24_gimbalproblem.param
    https://storage.ning.com/topology/rest/1.0/file/get/3702114094?profile=original
    • I would really appreciate if someone could post a .param file of a working tarot t2d setup.
  • Hi Randy. I installed 3.3.1 RC1 today to test and issue which I have with no SBUS output on a Pixhawk controller. I´m trying to connect a Storm32 controller. If I make a direct connection between the X8R and the ST32 I get no problem, but I i try to make it through the pixhawk I get no response. I have set BRD_SBUS_OUT to 1
    • Sbus out is not implemented yet. Just make a Y harnes for your sbus. Also, it is much better to use sbus ou pin for RSSI so you have that info on your OSD.
      • I think Robert once said that it was working. Maybe is not so difficult to implement. I would also be saffer than using a Y cable
  • Hi Randy,
    Is there a work around for my alexmos simplebgc gimbal? I was able to use it without issues on the previous 3.3 beta build. but now it seems I cannot control the pitch. Previously, i use ch6 on my radio. The gimbal was connected to aux1 like before. MNT_Type was set to servo. but now on the latest build, i cannot use it properly..
  • Maiden flight on ac3.3, it was really stable :)
