Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I would really appreciate if someone could post a .param file of a working tarot t2d setup.
  • Hi Randy. I installed 3.3.1 RC1 today to test and issue which I have with no SBUS output on a Pixhawk controller. I´m trying to connect a Storm32 controller. If I make a direct connection between the X8R and the ST32 I get no problem, but I i try to make it through the pixhawk I get no response. I have set BRD_SBUS_OUT to 1
    • Sbus out is not implemented yet. Just make a Y harnes for your sbus. Also, it is much better to use sbus ou pin for RSSI so you have that info on your OSD.
      • I think Robert once said that it was working. Maybe is not so difficult to implement. I would also be saffer than using a Y cable
  • Hi Randy,
    Is there a work around for my alexmos simplebgc gimbal? I was able to use it without issues on the previous 3.3 beta build. but now it seems I cannot control the pitch. Previously, i use ch6 on my radio. The gimbal was connected to aux1 like before. MNT_Type was set to servo. but now on the latest build, i cannot use it properly..
  • Maiden flight on ac3.3, it was really stable :)
  • This afternoon another fligth but FPV now, pos hold, some less wind and no simple, all good.
    • Cala I think you are just having too much fun :D
      • Yesss!, I acumulate and now I have to use all together ;) ....tomorrow rainy forecast :(
  • Hi! i just flashed the latest AC3.3, but now my 2axis alexmos gimbal does not work. on the previous build, I just set MNT_TYPE to servo. now it does not seem to work. can anyone assist me?
