Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Thank's
  • This reply was deleted.
    • So this is supposed to only happen when the compasses disagree by a large margin. This happens to me when both compasses get uneven interference - either because MOTCT is inappropriately applied (because my power module gives bogus readings on USB power) or when I mount my battery with the lead "exit" end close to the compass (which surprisingly generates large amounts of interference). Not sure if either of these is your problem, but I'll throw it out there anyway :)
      Greg,
      The interference could be because of some interference at the launch site (like a metal pipe in the ground) so you could try moving the copter or rotating it a bit.  Another alternative is to disable the internal compass by setting COMPASS_USE2 to "0".  That turns off the consistency check.
      • Disabling int compass solve mine
  • A big thank you to Randy, Leonard and all the developers as well as all the great people from around the world contributing to the discussion. 3.3.1 is absolutely rock solid, safety and stability have improved steadily in the year since I started out in this. It has been great fun for me as well as my High School Students, we have all learned a great deal thanks to this group.
    Thanks to all,
    Fly on
  • my gimbal now works fine on AC3.3.1 rc1 :) thanks again!
  • Does EKF use both internal and external compass data for processing? I know they don't switch in flight (if copter has both).
    Today I had EKF warnings for Mag.  The external compass is a good 6" away from the power wires, so I'm puzzled as to why EKF is complaining.
      DG,
      No the EKF only uses the primary compass which would be the external one if you've got it attached.
      • I was having all sorts of issues w/ my little copter w/ auav-x2 board. Auto missions were very uneasy/wiggly, it toilet bowled, it had all sorts of random AHRS and arming errors.  I made lots of posts about it over the summer, but finally found the cause recently..
        Even though I have an external compass, it was the internal compass.
        After trying everything else, I decided to disable one compass, and just use the other.   If I disable the external compass, north is no longer north, no matter what orientation I set the compass as....  Basically, the internal compass is no good.
        If I use only the external compass, all is good.  No more random drifting off in some direction.  No more toilet bowling.
        I guess the developers would know more than me, but my observation has been the bad internal compass did indeed cause issues when both compasses were enabled.
          ScottW,
          That's a bit strange 'cuz the EKF shouldn't be accessing the internal compass.  Basically the internal compass shouldn't be used for anything except the consistency check.
