Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Disabling int compass solve mine
  • A big thank you to Randy, Leonard and all the developers as well as all the great people from around the world contributing to the discussion. 3.3.1 is absolutely rock solid, safety and stability have improved steadily in the year since I started out in this. It has been great fun for me as well as my High School Students, we have all learned a great deal thanks to this group.
    Thanks to all,
    Fly on
  • my gimbal now works fine on AC3.3.1 rc1 :) thanks again!
  • Hi Randy, I currently using AC 3.3.1. Last time when i test my hex-copter with mission planner 3.32. Firstly, I sent command to take-off to 5 m, it's ok. But when i send commands to take-off to 10 m, it didn't work. Then I switched the firmware to AC 3.2.1, I tried take-off to 5 m and then take-off to 10 m, it worked. Could you give some suggestions. Thanks so much.
  • Does EKF use both internal and external compass data for processing? I know they don't switch in flight (if copter has both).
    Today I had EKF warnings for Mag.  The external compass is a good 6" away from the power wires, so I'm puzzled as to why EKF is complaining.
      DG,
      No the EKF only uses the primary compass which would be the external one if you've got it attached.
      • I was having all sorts of issues w/ my little copter w/ auav-x2 board. Auto missions were very uneasy/wiggly, it toilet bowled, it had all sorts of random AHRS and arming errors.  I made lots of posts about it over the summer, but finally found the cause recently..
        Even though I have an external compass, it was the internal compass.
        After trying everything else, I decided to disable one compass, and just use the other.   If I disable the external compass, north is no longer north, no matter what orientation I set the compass as....  Basically, the internal compass is no good.
        If I use only the external compass, all is good.  No more random drifting off in some direction.  No more toilet bowling.
        I guess the developers would know more than me, but my observation has been the bad internal compass did indeed cause issues when both compasses were enabled.
          ScottW,
          That's a bit strange 'cuz the EKF shouldn't be accessing the internal compass.  Basically the internal compass shouldn't be used for anything except the consistency check.
  • Testing 3.3:
    Was really pleasantly surprised: The satellite Spektrum compatible receiver works! Even the channels are in the right order! Great! Love it!
    Henri.
  • Thank's Randy, we don't have to change rc1, it's the same no?
    Another thing, when I installed the 3.3 with pix my OSD read all in 0, I have to change sr values before some reading, now I noticed another persons with same problem, perhaps it's usefull to have the correct SR values for OSD as standard params not to have that problem? or if you are not using osd you need different params?
    http://diydrones.com/forum/topics/adding-extra-functions-to-minimos...
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
