Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
my gimbal now works fine on AC3.3.1 rc1 :) thanks again!
Hi Randy, I currently using AC 3.3.1. Last time when i test my hex-copter with mission planner 3.32. Firstly, I sent command to take-off to 5 m, it's ok. But when i send commands to take-off to 10 m, it didn't work. Then I switched the firmware to AC 3.2.1, I tried take-off to 5 m and then take-off to 10 m, it worked. Could you give some suggestions. Thanks so much.
Does EKF use both internal and external compass data for processing? I know they don't switch in flight (if copter has both).
Today I had EKF warnings for Mag. The external compass is a good 6" away from the power wires, so I'm puzzled as to why EKF is complaining.
DG,
No the EKF only uses the primary compass which would be the external one if you've got it attached.
I was having all sorts of issues w/ my little copter w/ auav-x2 board. Auto missions were very uneasy/wiggly, it toilet bowled, it had all sorts of random AHRS and arming errors. I made lots of posts about it over the summer, but finally found the cause recently..
Even though I have an external compass, it was the internal compass.
After trying everything else, I decided to disable one compass, and just use the other. If I disable the external compass, north is no longer north, no matter what orientation I set the compass as.... Basically, the internal compass is no good.
If I use only the external compass, all is good. No more random drifting off in some direction. No more toilet bowling.
I guess the developers would know more than me, but my observation has been the bad internal compass did indeed cause issues when both compasses were enabled.
ScottW,
That's a bit strange 'cuz the EKF shouldn't be accessing the internal compass. Basically the internal compass shouldn't be used for anything except the consistency check.
Testing 3.3:
Was really pleasantly surprised: The satellite Spektrum compatible receiver works! Even the channels are in the right order! Great! Love it!
Henri.
Thank's Randy, we don't have to change rc1, it's the same no?
Another thing, when I installed the 3.3 with pix my OSD read all in 0, I have to change sr values before some reading, now I noticed another persons with same problem, perhaps it's usefull to have the correct SR values for OSD as standard params not to have that problem? or if you are not using osd you need different params?
http://diydrones.com/forum/topics/adding-extra-functions-to-minimos...
Copter-3.3.1 is out as the official release now. Thanks for the confirmation from Miroslav, Yssaril, RandyB, JoeG, Stephan and perhaps a couple of others that -rc1 seemed ok!
OK that was strange.
More on the 3.3.1 accel[1] not healthy messages
So trying to figure out what was going on. I decided to clear my logs, then try again.
I did the following:
I turned on my RC transmitter (It was not turned on previously)
I cleared the logs in the PixHawk.
I waited a while, then rebooted the PixHawk.
It seemed to complain about compass and other issues. So I re-calibrated the compass (at my desk, probably not best, but I decided to do it).
I then re-ran the Accelerometer calibration, this time it walked through the '"place on left side, place on right side, etc."
I even tried to arm (no flight battery) and then disarm. It all seemed to go ok.
I had a lot of 'bad AHRS' messages, and the HUD in Mission Planner seemed wonky, it was showing the copter on its side, but it was level.
So I rebooted the PixHawk, now the HUD shows level.
AND NO more errors or warnings.
Again, this is all while powering the pixhawk with my USB cable, no flight battery.
So, am I ok now? What other tests should I make before trying to fly?
Attached is my logfile, just in case anyone is asking.
