Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I have two Pixhawk running arducopter with version 3.3.1 and one with
3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
Wil there be ever oneshot support with pixhawk in the future?
+1 For that!
It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped. I know Leonard Hall wants it as well so that increases the chance that it'll happen.
If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
yes please, oneshot support and blheli 1wire update through copter software
So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
I for see a lot of questions
Do the latest firmwares support V and T setup for hexacopters at all?
I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors). It worked out OK.
Duffy,
I'm afraid we only support X and + for the Hexacopters. It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
