Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I think this was just a rationalization of what the value needs to be.  I've been pushing for it to be 4500 for a long time, which is what I typically run.
  • test flight a while ago, hovered it  3 meters away from me. My quad went to failsafe due to low battery. but instead of landing, it performed RTL instead of LAND. I thought it should choose whether to LAND or RTL based on hardcoded 5m rule? is this normal? Luckily i was able to switch flight modes to cancel RTL else it should have hit the wall.
  • This reply was deleted.
      I don't see anything in particular wrong.  I'd recommend trying a few things:
      • re-calibrate the ESCs
      • do the motors test to ensure the motor order and direction is correct (check the props too!)
      • if the above doesn't help, try going back to Copter-3.2.1 (it's still available through the MP's previous firmware link) so that we can be sure it's a firmware issue.  If Copter-3.2.1 works but Copter-3.3.1 doesn't then it's likely a firmware issue and we can look into it further.
    • I had a quick look.  Has this vehicle flown before?
      I don't see anything wrong though I'm not the expert in multirotors.  I see your motor outputs are about 1250uS PWM on the first test.  Then the second test they don't go above 1500, I think it flipped over?
      I suspect it might just be that your multirotor is overpowered, or the ESC's aren't calibrated properly?
  • I have two Pixhawk running arducopter with version 3.3.1 and one with
    3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
    • +1 For that!
        It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
        • If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
          • This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
