Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Well Hello everyone, nice to be back in this old familiar forum! Sorry for the Intrusion, just wanted to say hi to all the people that taught me something about flight controllers and piloting during my APM 2.6 days. After a Tragic and Horrible Decision to try out XAircraft MINIX, i am now back to what works, Pixhawk 2 and Solo.
    Just a Quick question if you guys dont mind (because most people who have a Solo or New pixhawk dont really remember APM 2.6) What happened to the parameter that turned your aircraft Tail IN when Landing from an RTH? i know the WP_YAW_BEHAVIOR for pointing home, but cant find the the Tail in Land parameter. if i am in the wrong place, please be kind to a weary pilot who  hit his own RTH button only to land here, please point me in tot he direction of Tower/Solo questions
    nice to be back i have missed you maniacs and brainiacs!
    Thor
    • Re-Welcome Thor, congrats for your Solo, perhaps you can find much more complete the instructions now if any one give you the answer http://copter.ardupilot.com/wiki/arducopter-parameters/   I'm only use the param that you mention, please share if you find what you say.
      • Hi Cala,
        I looked at that list but i didnt see the Param but i will look again and check back again! thanks for responding to my comment.
        • TMT, I have my WP_YAW_BEHAVIOR set to '1'. 'Face next waypoint' and it comes in on RTH and rotates to launch heading for landing
          Cheers. RB
          • Hey Randy thanks Alot!! i knew it was an easy setting!!! i just couldnt remember from APM 2.6 days how i set it!! i appreciate your response!
  • Autotune woes!
    Still having no success getting a decent tune on my QAV250 after upgrading to BLHeli 14. I upgraded again to 14.2 and discovered that one of the ESC's hadn't calibrated properly, so I fixed that and had another go. Basically the copter tolls back and forth like its on a soggy elastic band and its pretty easy to flip over.
    I'm just trying to tune roll at this point. The first tune resulted in it still rolling back and forth with lots of overshoot like it was on a soggy elastic band. The tune didn't complete because of battery failsafe. Log attached.
    I then lowered the PIDs and Stab P to try and get better initial stability which resulted in an even more unflyable copter - it flew sideways and I could recover it at which point it flipped and crashed. Not much of a log but its attached. I'm guessing that one of the values is the wrong thing to do, but if Leonard is able to give me some hits I would be really grateful!
    88.BIN
    89.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3702125949?profile=original
  • HI. Just next post to add PID tune page
    https://storage.ning.com/topology/rest/1.0/file/get/3702125700?profile=original
  • I may be in a wrong thread, but since I am using Pixhawk with 3.3.1 firmware I think my question is relevant.
    My setup is shown in attached pic. It is modified Flamewheel clone with RCTimer 2610-920 kv motors, Platinum 30A ESC's. I made it for night flight photos (and possible FPV, so there are 3D field separated camera (Blackbird-1) with 2W 930MHz video transmitter). For regular flight there are two 10W  60 deg. LED and for light effects 100W focused LED on 1 axis gimbal. All peripheral equipment powered from separate battery. Lights controlled via RC ch 9 and 10 through Turnigy solid state relays. The whole thing weight is 2045 g with both batterys, it hover at 45 - 50% throttle.
    It flys perfect in Stabilize mode. I tested vibrations, it is below +/- 0.1 g on all axis. When I switch to AltHold mode it almost hold but slowly loosing altitude, it is erratic in Loiter. In log it shows EKF_CHECK-2 error. I read through many discussions on several forums. In most cases it is either vibration or Yaw-error (mine is below 0.2).
    I just did complete calibration of both magnetometers with all peripherial ON (errors were balow 0.2) and flew it for 3 min on my backyard - same effect - got EKF error right after switching from Stab to AltHold (did not even use Loiter). Log.bin file from latest flight attached.
    Any ideas? I am kindly asking for Randy's comments (it seems that he is the most active in the discussion of this issues in many forums).
    Could it be PID tuning, I am still on default values (at first test flight it seems stable enough and pretty responsive, so I decided not to tweak it.) Tuning snapshot below.
    It does not seem to paste jpg file in edit mode. will post it in next post.
    2015-11-15 17-46-19.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702125575?profile=original
  • Since 3.3.1, it seems there is a regression with NMEA GPS support compared to 3.2.1. For example, these are NMEA messages refreshed at 4hz:
    $GPGGA,062233.25,3639.3432626,N,11708.7509099,E,1,10,1.3,194.875,M,-6.60,M,,*4A
    $GPRMC,062233.25,A,3639.3432626,N,11708.7509099,E,0.059,281.7,091115,0.0,E,A*36
    $GPVTG,281.667,T,281.667,M,0.059,N,0.110,K,A*2F
    With 3.2.1, Mission Planner shows "3D Fix". However, with 3.3.1, Mission Planner shows "No GPS" or "No Fix" most of the time. Mission Planner shows sometime very briefly "3D Fix", but it turns to "No GPS" or "No Fix" immediately.
    When I checked the code at https://github.com/diydrones/ardupilot/blob/Copter-3.3/libraries/AP... I do not see anything unusual.
    Any idea?
    • is this with a m8n module? And why are you using NMEA?
