Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Leonard,
An update on this. I have done some manual tuning on Roll using the Dave C method. The results are ok but I note a couple of things:
Roll_P needs to be quite high for good response, its much too soggy otherwise
Roll_I set to the same level results in unflyable oscillations.
So I conclude that autotune will never be able to tune this copter if it sets Roll_P == Roll_I.
Roll still feels less responsive than pitch. Not sure how I can improve this. I'm also going to try go back to simon K to see what different that makes (but with active braking enabled).
Thoughts?
2015-11-20 13-10-14.bin
I've drastically improved roll responsiveness by upping ATC_ACCEL_R_MAX. Autotune had set this to a very low value (53000), I increased it to 180000 and now the copter feels much, much more responsive.
So the $1m question is if I now try autotune on this - which actually feels pretty good - will it make it better or worse?
Too much wind at the moment to try it out!
Finally completed an autotune on roll. It resulted in very low Roll_P (0.04) and Roll_I (0.04) - very different to my manual tune above which has Roll_P (0.16) and Roll_I (0.03). Difficult to say which feels better as they both fly quite well. The autotune version seems softer. Be interested in opinions on which is better and pros/cons of both.
Autotune log
105.BIN
Hello Everyone,
I'm doing some test with some new multirotor.
I have problem with land detector.
This is the video.
https://youtu.be/BaYIRX3O9cA
Attached to this post the log.
Can you find the problem?
AC 3.3 Stable on VrBrain 5.
2.BIN
I think you've stumbled onto a little loop hole in our landing detector logic.
The THR_MID is very low (only 300) and the THR_MIN is quiet high (200). This means the throttle out can never get to 1/2 of THR_MID (i.e. 150) so the landing detector won't work.
So I think either THR_MID should be raised (to maybe 400 although it depends upon the frame) and/or THR_MIN reduced (130 is the default.. it must be brought under 150).
THR_MID and THR_MIN changed. Problem solved =D Now I can land my copter in the correct way.
Thank you very much Randy, you solve everything (=
Hi Andrea,
Could you please do an accelerometer calibration and set your log bitmask to 157693 and do this test again. This should give us the logs we need.
I had an unpleasant throttle cut when flicking from Stabilize to Loiter on the new 3.3.1 the other day, and I haven't been able to figure out what caused it yet. I have just upgraded from 3.2 which has flown fine for a long time, but on my second or third flight, after landing to fix the camera and then taking off again, the moment I flicked into Loiter from Stabilize it dropped (3 metres) to the ground out the sky. From the logs I see that just after mode change to Loiter at 10:53:40.932 Throttle was cut from 500 down to 129 over a couple of cycles without me moving the throttle stick from centre position.
It's a DJI S800 Evo running pixhawk, good conditions, no sun, no wind. It had been flying fine on Arcudopter 3.2 for several months until now.
It just suddenly happened on 3.3.1 on my second flight. (The first flight went ok, although the copter seemed very jumpy). - GPS situation looks good, Vibrations look ok. Is it an EKF problem?
I'm Reluctant to try it again so I might downgrade to 3.2 again for now...
ArduLog 3.3.1 sudden drop on Loiter mode.BIN
PiersC,
First off, I'm very sorry about your crash. .. and unfortunately I believe you've uncovered a bug. The issue appears to be that the desired climb rate is not being reset properly as the vehicle enters Loiter. Instead of being reset to zero (or better yet the vehicle's current climb rate), it's being left as whatever it was the last time the vehicle was in Loiter.
Below is a graph of the issue recreated in the simulator. Around the middle (see "6") the vehicle is in Loiter and the pilot's throttle is pulled low which demands a -ve climb rate (5m/s in this example). The vehicle is next switched to Stabilize, throttle is raised to mid and then switched back to Loiter. At this point you can see the climb rate (in green) dips as the desired climb rate starts again at -5m/s instead of zero.
Thanks very much for the report though!
