Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Paul: try with Tower and "follow me"
http://diydrones.com/group/tower-droidplanner/forum/topics/follow-m...
Hi everyone,
I was enjoying 3.3.2 but suddenly had crash :( . I think one of the motors/prop/esc just stopped at ~55m and then just saw it falling
Could you please help me figure out what happened ?
Log here: https://www.dropbox.com/sh/033wkud5adiw7b9/AABEjRVYZaQEs6d8-mLwrSyN...
2015-12-25 16-56-49.bin
Anyone kind to take a look please ?
I cant really figure out what happened. It was fine before 3.3.2...
it looks a mechanical failure in motor 3, check it
Thanks for taking a look Cala.
It also could be #4 right ? and 3 tries to compensate ?
It is for sure the motor or could be the ESC ?
coincidence or not the ESC #3 got pretty damaged upon hitting a wall (some capacitors and a few other components were gone), it could also be the case that it was this one that caused the fall and coincidentally the one that hit the wall, right ?
I've bench test all the motors / and the three esc's remaining and everything works. 55m fall and not even a single propeller broken (damn APC propellers are made of steel ahah)
For me motor 3 is the problem, I'm not an expert but if I'm incorrect anyone else shure correct me watching the graphs. esc can be the problem too but a pitty that you can't test it. If you can't find nothing, repair it, test near the floor and then read log if you notice any ERR message, check connections and wires too, looking for any little damage.
hey there, I have a 250 sized quad running AC 3.3.2 on a PX4mini board by airbot, there were couple of compass related issues which I think I've sorted out, however when I attempt to take off copter starts spinning around itself very fast (keeping horizon though, kudos devs!) I've tried to determine what's the issue is but as far as I see from the logs there are no errors and RCin4 corresponds to actual stick movements. Can someone take a look at the log below to help identify the issue?
p.s. log is from AC3.3.4dev but the quad behaves the same way on AC 3.3.2
2015-12-28 22-47-36.bin
Finally the rain and wind stopped! Did some flying with 3.3.2 and saw some weird behaviour. I occasionally get these huge spikes in ErrRP, ErrYaw and EKF SV & SP. Haven't seen these before that I recall. A couple of flights show these the rest do not. The flying conditions were calm and the copter behaved well in flight, but these spikes seem bad. I can't find any correlation with GPS glitches, high vibes, mag interference or any of the usual suspects.
[Note to Leonard, I also tried some 5045BN's for the first time and needed even greater divergence between P&I on both Roll and Pitch for stable flight. I've pretty much given up on autotune for this copter at this point. The attached log is for 5030's however.]
124.BIN
Hey quick question. On one of the vehicles I work with, I see severe "bouncing" in auto-land due to prop wash messing with the baro. Moving the baro isn't really an option. Would adding a sonar or lidarlite sensor eliminate this behavior? Am I correct in thinking that a sensor like this would eliminate the perceived swings in vertical velocity seen by the baro by providing a more true altitude? Thanks.
Cover your baro with dense foam to block from prop wash and light.
47
48
49
50
51
of 449 Next
