Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Thank's Joe, that exact reaction that the copter have, I jump the updated instructions; I have to say that reaction when lost gps was much better than some years ago when the guy flyed like a cohet when he lost gps.
  • I think you forgot the log
    • It was 7.08 mb and didn't upload it, now works?
  • Same here, i thought it has something to do with my thr_mid but I guess this is a bug on the latest beta release. The altitude hold seems to drop the quad's altitude
  • Hello. Well, if you speak about crashs of drones, so maybe this information will be helpful for you
    http://www.rcfair.com/en/blogs/view_entry/13279/
    Crash-proof quadcopter. The basics of how to avoid major repairs (Pt. 1, Mechanics)
    I've been flying an F450 quad via FPV for about 4 years now. It endured many crashes (free-falls), some were caused by my actions, while some had to…
    • There are lots of fancy drones with hard to find replacement parts. Keeping it simple like you did helps a lot. Where did you buy your arms / frame? I built one like that it broke way too easy. Cheap brittle arms I bet the ones you have are better.
      • Richard,
           Where is the file for the latest 3.4 dev? I'd like to try it on the test quad.
        • In mission planner select beta then do control Q will bring up the latest dev.
          • Ah yes, now I remember! Thanks.
            Did you recalibrate accels and compass?
