Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thank's Joe, that exact reaction that the copter have, I jump the updated instructions; I have to say that reaction when lost gps was much better than some years ago when the guy flyed like a cohet when he lost gps.
I think you forgot the log
It was 7.08 mb and didn't upload it, now works?
yea that worked
http://www.rcfair.com/en/blogs/view_entry/13279/
There are lots of fancy drones with hard to find replacement parts. Keeping it simple like you did helps a lot. Where did you buy your arms / frame? I built one like that it broke way too easy. Cheap brittle arms I bet the ones you have are better.
Richard,
Where is the file for the latest 3.4 dev? I'd like to try it on the test quad.
In mission planner select beta then do control Q will bring up the latest dev.
Ah yes, now I remember! Thanks.
Did you recalibrate accels and compass?
23
24
25
26
27
of 449 Next
