Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • By "new" I mean it was shipped in July 2015 and has never been crashed. That should have been made after the known issues that plagued my last Pixhawk.
  • Hello Vesselin,
    first of all thank you very much for your detailled and well explained analysis. It is a big help for me as a arducopter beginner.
    You consider the ESCs (or at least the "lonely" one) to be the reason for the crash. And indeed there is a lttle hole in the heat shrink tube of the ESC that drove the "lonely motor". Severeal tests on the bench after disassembling the showed any anomality.
    The ESC (AfroSlim) is rated at 20A and on full throttle (servo tester) there is a draw of 13A.
    Nevertheless, the log should´ve recorded until the craft hitted the ground (Alt=0) even if there had been problems with one ESC, shouldn´t it? The Disarming ends the log at a height off 20m.
    It´s a pity that there´s was no RC Out logged at this particular flight.:( The log bitmask is now set to 176 126
    On another forum, there was said, that the Disarming was due to the large DesRoll-Roll and DesPitch-Pitch deviation of more than 30 degree. For me, that could be conclusive as well.
    What do yout think about that?
    Again, thank you for your help!
    • The extremes of flight, where no reaction of motors, the controller detects as crash - so there "crash" disarm, similar to the situation where copter hits a structure in air. Then everything stops, no recording.
      • This reply was deleted.
        • Did you check the settings values if same in the 3.3.2?
          Sometimes when you import the settings from previous release version, they are different or some not imported at all. Have to check all PIDs, flags, etc. manually.
  • Midflight-Disarm -> Crash
    Hello together,
    I´d like to share my latest experience with you:
    To test the redundancy capacities of a recently built Coax Octocopter X8, I turned off Motor 1 to check the emergency flight behaviour.
    In Stablilize and AltHold Mode, the reaction were OK. Mainly during faster Yaw-Turns the crafts began to shake but always recovered
    As final check I tested RTL. Even though there were some unintended Yaw-turns while retunrning to home-point, the craft managed to reach it.
    As soon as the descending started, all motors where stopped/disarmed and the craft fell to the grund from app. 20m height.
    Even if there were quite unstable moments during the whole test flight, I´m quite sure, that the craft would´ve recovered on the landing process, if no Disarm-Command would´ve occured.
    I´d really like to get your feedback and would be happy if someone (Randy?) could have a look at the log file.
    There are huge and very fast roll amplitutes before the Crash-error, I can´t imagine that they are even physically possible with this big and heavy craft (maybe some kind of EKF error?).
    Kind regards and thank you in advance!
    Ulrich
    Specificiations:
    AC 3.3.2
    AUAV X2 Flight Controller
    8x 4225 390kv Motor, 17x6 Folding Prop
    AUW: ~ 3800g
    63.BIN
    • The controller performed well for such “disabled” bird…
      3702619121?profile=original
      All the flight is quite good, but clear instability in the Roll after both RTL commands. The power to the controller is lower – 4.91V, should be about 5.2V normally. Probably not big issue for this flight.
      Among all the flight the controller gives good Throttle Out. But again after the both RTLs, the Throttle Out have high peaks, and at the 4 min flight time it reached the maximum – 1000.
      3702618941?profile=original
      All this leading to the conclusion that the controller performed well until height of 20m, keeping the bird in decent flight.
      After all the permanent Roll oscillations and constantly overloaded ESCs, the final Throttle Out 1000 browned the ESCs and motors stopped.
      It happened at line 63.
      3702619162?profile=original
  • I did some flights with 3.3.3 in pos hold with nothing strange; yesterday I installed the gimbal and assign ch6 to tilt movement as instructions explain, today afternoon forecast indicates no wind so I went to check the gimbal and more functions from 3.3.3, forecast was incorrect but I tried anywere, GPS had some gliches for first time, I was near trees but not the first time that I fly near trees without problem. I try pos hold and guided mode, Pos hl sometimes well some not, first guided test well, second guided test a gps glich and fly near trees so landed and went boxes to look logs  (I hope was the best choice), I found fligth mode 16 err in logs and exf err and suposse  gps cosecuence, In the afternoon, strong wind, I was intrigated and try far from gps interferences and well fixed gps wires with fastik, at the begining the err mode and exf appears again but, this time no gps gliches, I only change firm and program the ch6 for gimbal, I re -check the pwm values and looks well ;What could  be happened?
    The last flight log attached  https://www.dropbox.com/s/jsg1ekw89npghec/31.BIN?dl=0
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    • It's looks something assigning ch6 to gimbal perhaps, because I check older logs and nothing strange, It's looks that affect pos hold mode but I don't know how to solve, any idea? I checked ch6 in basic tunning and is assigned to NONE
      • I recalibrate the radio, little test and now looks well again, I'm going to continue testing.
        But refering to code, I'm not shure if it not an issue that log doesn't indicate the gps glich, only says EKF 1 or 2 err. This is the log with that problem. https://www.dropbox.com/s/1z8vp1ul5rkijpo/30.BIN?dl=0
