Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
BTW Bill Booney... unless I'm thinking backwards here [ wouldn't be the first time ] the 'Value' is the current / 'new' / changed value. It old / previous settings are what APM P2 is listed under 'new value'... so that seems backwards no?? In other words... I turned off COMPASS_USE2 =0 that's the current param in the pixhawk.
Your baro and alt track don't look so good
Now I get this
GPS: u-blox 0 is not maintaining a 5Hz update
That's a new one....
I have had the same message on the ground, inside my home with a 3DR6lea-h, but it never appeared via Tower and that's what I use in the field.
I've been using this same gps for 2 years. Probably just better reporting in 3.4 of variances like this... maybe
Here's another flight. Seems okay although it's bit mushy... time for some PIDS tweaks again. That's VERY cool you can select alt hold instead of land!!! and... I set the delay for the maximum time. So if something goes wrong over water I have more hope of getting to it and taking over.
Baro and gps alt seem on the same page here
2.BIN
I've seen this happen with a cheap BeStar BN-800 m8n module, worked fine at 2Hz but not at 5Hz. The BN-880 seemed to have fixed the issue.
It seems they changed the name and now are called Beitian BN-800 and BN-880 instead of BeStar though it's the same modules :)
Is it something I should be concerned about? Is this the refresh rate? Thanks Craig.
If it is working fine then no nothing to worry about. If you are seeing GPS glitches and sat count/hdop issues then yes. If you ARE having issues then connect to ucenter and set it to a lower Hz until it stops dropping. Save the config and then remove the TX lead from the flight controller going to the RX of the GPS to keep APM from auto configuring the module to run @ 5Hz. [There may be a setting now in mission planner to stop the auto update but I don't remember]
I read on other threads that 3DR will leave the open Source community to go other ways with solo and so on..
What does this mean for Arducopter, will there still be a on going development of Arducopter and will the new project Pixhawk 2 be supported ?
