Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I think you are lucky that it worked for you before :) 3.2 & 3.2.1 both showed mostly garbage for me on Windows with APM & MP. APM worked a little on linux, but now it's garbage also. I don't think this problem is new to 3.3...
  • This reply was deleted.
    • @Andrei
      I have got same "yellow-red-yellow-red" led pattern and "EKF variance" message. I dont know what is the meaning of this led pattern.
  • Autotune again
    below the results of autotune - just R/P - with my Y6B with large props (15").
    Stability / response is GREAT!
    Especially fast descend, what was a really problem before, now works nearly perfect.
    Great work!
    3701983801?profile=original
    2015-04-17 08-56-15.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3701984060?profile=original
  • I wonder if the Pixhawk 2(what is difference to Pix1?)Linux computers and gimbal control etc, from the Solo will also be available for DIY in a frame of our choice?
  • Hi randy!
    Maybe you can also add what was suggested by our fellow member here before, a 2 stage fail safe for the battery. Is it possible?
    The scenario is when the low voltage is triggered, RTL will activate, however, if the UAV cannot make it home with its remaining battery, the second fail safe will activate which will cause the UAV to LAND.
    Hopefully it can avoid causing damage to the UAV nor to anybody as it will not fall like a rockf from the sky since it will gradually land.
    Thanks in advance!
      It's on the to-do list here.  Just a matter of a developer picking it up and implementing it but it's hard to make promises when that might happen.
      • Thanks. I'm happy with the thousands of features Arducopter has now. It just amazes me how much work you and the team have done. Huge congrats to you all. I hope that some day I get to buy you a beer or two or three...
          Darrell,
          Thanks for that.
          Yes, the distance limited by remaining battery is a really great feature.  I don't think it'll make AC3.3 but I'll go out on a ledge and say it'll very likely make AC3.4.
    • I think it would be cool if the battery failsafe tripped _before_ the copter reached a point of no return. I think that's one of the coolest features I've seen in some of the new copters. You can't really fly them past the point where they don't have enough battery to return. I don't know if you can over ride that or not but it is a cool feature.
