Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Does the baro show the altitude is correct in the log or tlog?
          • The log shows the same fluctuation I see on the taranis telemetry.
  • For my purpose Acro and fun Copter use this release RC3 is the best ever. Handles very stable and precise.
    I just have one remark concerning YAW. This issue occurs only when  ATC FF  is turned "on".
    Autotune sets following values
    ATC_ACCEL_P_MAX 95414.84
    ATC_ACCEL_R_MAX 116621.5
    ATC_ACCEL_Y_MAX 14070.54
    What i noticed is that YAW seems to accelerate much lower then Pitch and Roll. Therefore interaction between Roll,Pitch and Yaw has very poor performace, For example, when i'm peforming a dynamic turn Yaw is to slow to interact with PItch and Roll. At the end of the move Pitch and Roll are at the end point and yaw is half of the way.
    • Hi Leonard,
      looking on the DesYaw / Yaw logs, i don't see differences between the new logs and the old one's without ATC FF.
      but ok, i'll do some testing. Basically interaction between Roll,Pitch and Yaw is pretty important on 3D.
      This are the newest Autotune values. Starting from AC3.3 RC3 i use the Anti Vibration Mount.
      "AC3.3 RC3 I" is the newest one which i've done today on open field, "AC3.3 RC3" was a quick one from yesterday in the garage. There are some difference in STB.  i will do more testing soon.
      AC3.3 RC3 I AC3.3 RC3 AC3.3 RC 1 III
      RATE_PIT_P 0.056 0.05 0.074
      RATE_PIT_I  0.141 0.126 0.185
      RATE_PIT_D  0.004 0.004 0.0053
      RATE_PIT_IMAX  200 200 200
      RATE_RLL_P 0.065 0.061 0.098
      RATE_RLL_I  0.163 0.152 0.247
      RATE_RLL_D 0.0042 0.004 0.005
      RATE_RLL_IMAX 200 200 200
      RATE_YAW_D 0 0 0
      RATE_YAW_I 0.045 0.048 0.073
      RATE_YAW_P 0.45 0.488 0.734
      STB_RLL_P 11.659 14.422 9.319
      STB_PIT_P 15.84 8.101 7.403
      STB_YAW_P 6.954 5.462 7.822
      ATC_ACCEL_P_MAX 95414 95432 90272
      ATC_ACCEL_R_MAX 116621 114359 99212
      ATC_ACCEL_Y_MAX 14070 16228 14105
      Hi Poraroli,
      You can safely increase the ATC_ACCEL_Y_MAX until you are happy. All that will happen is it starts to bounce back as it stops.
  • I appear to be unable to calibrate the accels, every time Bad AHRS and the horizon is wandering. Board and settings are working fine on 3.2.1.
    My board (AUAV-X2) is installed upside down, and as the accelerometer is backwards I normally use AHRS_orientation = 8. I have tried a few orientations now, all with the same result. is it possible AHRS_orientation is not being honored correctly?
    • I see this issue has been encountered by others and is being worked on, see https://github.com/diydrones/ardupilot/issues/2266. Hopefully the fix will make it into rc4.
      • I've recently seen the behavior you are describing as well, but I don't believe it is related to the problem I reported here.   The issue I reported in 2266 only causes small constant errors in roll or pitch.  I did submit a pull request for 2266 last night.  If you can't find the cause of the erratic behaior, you may want to file a separate bug.
  • Tryin 3-3-rc3 on small 600mm CF quad.
    - Could not calibrate accelerometers on the table using radio link. Was successful using USB link first go. ??
    - Compass calibration even with 2,500 + points didn't "auto accept" (using radio link)
    - Radio calibration using Taranis and "native" channel order (e.g. Throttle on channel 3 instead of normal 1) was easy through radio link.
    Using Quanum telemetry, I did disable on board failsafes related to battery..
    Flying test:
    Take off was smooth and easy in stabilize.
    Moving on to ALT Hold was very good.
    As soon as I changed to loiter, the quad decided to go where he felt better and crashed.
    Perhaps someone could tell me more about it looking at the attached bin file?
    Thank you in advance.
    Henri
