Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Rob for the landing gear support, it's a great feature. I've got it working well with a tarot 650 sport via a switch and landing command in mission. Is there any way of getting the gear to retract through a mission, or any other automatic way, even if using a custom command or controlling the pwm? It would be great to be able to control the gear when doing complete missions from gcs/tablet app. Thanks very much for your work so far on this.
Cool, I will look forward to test it ;)
All with "APM:Copter V3.3 RC4"...
Nice video Marco,
Is it with a VRBrain?
And, did you use Region of Interest and Auto Mode during the shooting or is it a manual flight with camera control from the ground?
Thanks,
Marc
Mixed "Alt-Hold" and "Stabilize", the camera control is totally on the ground with dedicated tx and remoted video.
Gimbal is three axis, 360° continuous pan rotation, Pixhawk board with M8N gps.
Marco,
Was that filmed with a 3 axis gimbal setup or with 2 axis gimbal? Very nice video demonstration.
Germany...
I'm sorry, some friends ask me why i don't put music in all my videos, this is one of the reasons...
Hey Marco, check out the free music options directly from Youtube. Lots of choices. This is what I use now.
Looks really nice :-)
