Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        Hi Tim,
        That is part of the algorithm.
        Glad you are happy with the results!!
        • Hi
              Yes i think auto tune is truly sorted now.   just one thing after autotune completes I land with autotune selected and as soon as the legs touch down  the tri (y6) copter does a bucking bronco act, finaly fliping before i can disarm . This has happened every time ( thank heaven for soft grass) normal flight landings are easy(stabilise)
             Any way Thanks again for working on v3.3
          Tim
  • This reply was deleted.
    • Hey Terry
      Pls do this -> "The check can be disabled by setting ARMING_CHECK to Skip Param/Sonar." U found the Parameter in the Full Parameter List.
      Greetings, pit
        • i have a LIDAR and i must lift of the Copter for Prearm check to 50cm and then down. i´m not sure thats the same with a Sonar. i think so.
              • ARMING_CHECK  -33 , skip the Sonar/Rangefinder Check
  • hi! will the telemetry mod for X8R and taranis work with the latest firmware? I am planning to do the mod on my setup so that the telemetry data will be pass to the x8r receiver via smart port and Teensy board. but I am concerned if this will still work with the AC3.3rc4 or higher.. thanks again my friends!
